Beaglebone UART Speeds Not Correct
If you look in am3359_techref, table 19-36, page 3994, you will see, that the uart does not support your speeds
in the bad settings.
Walter
Sorry, ut is table 19-35.
Thanks. It is easy to get so involved with Linux that I forget about the tech ref.
Where in the header structure is the device dependent info defined? It seems like those settings should not be defined in asm/termbits.h if they are not supported.
