Hi all,
I’m currently investigating the Beaglebone for use in a research project and have been configuring all the serial ports. I’ve managed to get UART1, 2, 4 & 5 working without problems. However, I can’t find the mux settings required in order to expose UART3_RXD onto the expansion header. I’ve found uart3_txd on P9:42, so I assume that the RXD should be available on the connector as well, but I just can’t see it anywhere.
Is it me missing something obvious?
Thanks in advance
Phil
