[BeagleBone] Ubuntu 12.04 LXDE gui problem
Hi all,
I recently post my question here https://groups.google.com/forum/?fromgroups=#!searchin/beagleboard/beaglebone$20800X600$20LCD/beagleboard/Iqbq7wsD6fw/xldgiC823N0J
but I think I should start new topic to clear my question.
I port ubuntu 12.04 (source from RobertCNelson), and I modify function “beaglebone_cape_setup” to initialize my LCD panel. Now my LCD panel works fine and I can see LXDE desktop but in very bad image, you can see in my attachment.
I notice there are 2 strange points in boot log:
  1. FATAL: Could not load /lib/module/3.2.33-psp26/
    modules.dep: No such file or directory
    but my modules.dep is there, I cannot understand.
  2. Can’t build omap_device for da8xx_lcdc:lcdc
Also I cannot found the folder “/sys/devices/platform/omapdss/” in my system as I usually see in some google search result.
I guess my kernel did not initialize the graphic driver (fb or omapdss), some problem with overlay buffer or some thing like this. But I don’t know how to solve this.
Can anyone here help me. Thank you in advance.
Hi all,
Redirecting to Google Groups
"beaglebone_cape_setup" to initialize my LCD panel. Now my LCD panel works
attachment.
"sudo depmod -a" should take care of this...
2. Can't build omap_device for da8xx_lcdc:lcdc
Also I cannot found the folder "/sys/devices/platform/omapdss/" in my system
Well it's different hardware, the da8xx != omapdss...
some problem with overlay buffer or some thing like this. But I don't know
how to solve this.
It looks like it did initialize the framebuffer as you have an image,
but the corruption is either from a mis-configuration of the bits or
pins..
Thank you, Robert Nelson.
I will do so.
But this error occurs on booting stage, then when boot finish, I run this command, so dose it take effect to my system?
So what hardware do you mean? I use beaglebone A6.
And how can I change the LCD timing with da8xx driver instead of omapdss?
Currently I tried but I can change LCD timing by hard code in kernel only.
pins..
Can you advise how to debug this.
Thank you very much.
Regards.
I will do so.
Well... Reboot and find out...
system
What i mean:
BeagleBone: uses Davinci display hardware so uses the "da8xx"
framebuffer/driver..
BeagleBoard: uses Omap display hardware so uses the "omapfb" (omapdss)
framebuffer/driver
So looking back to your original statement:
system
Well, your running on the BeagleBone, and it does not have that hardware...
I'll leave that to someone else on this mainline list.. As i haven't
worked enough on da8xx to actually comment..
driver is here:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux.git;a=blob;f=drivers/video/da8xx-fb.c;hb=HEAD
pins..
Yeah, re-look at how you configured the RGB lines in the da8xx driver
and how it's wired to the board..
