Beaglebone USB hub
Hai all…
For my project I have to connect more than one usb devices with the beaglebone.
My question is can I connect all the these devices using single USB-hub…? Did the pre installed sd-card with the beaglebone support usb-hub…?
Thanks in advance…
Yes you can. Angstrom image supports. :slight_smile:
Cheers,
2012/6/2 Haris <harisprp@gmail.com>
Thnks OzenOzkaya for your fast reply…
I havn,t purchase the beaglebone yet…But I am working with beagleboard for the last1 year…
I want know that the pre-installed sd-card with the beaglebone support USB hub…I need connect a camera and a usb drive through the hub…
Hello, can you tell me what usb hub are you using?
Any hub in particular?
Regards
Frank
Belkin make good four port POWERED hubs.
They also make 7 port one, but I would recommend the 4 port …
