Stumped on why the rootfs is not being loaded, here is kernel output:
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
115 bytes read in 4 ms (27.3 KiB/s)
Running uenvcmd …
4191128 bytes read in 601 ms (6.6 MiB/s)
8518 bytes read in 47 ms (176.8 KiB/s)
Kernel image @ 0x80200000 [ 0x000000 - 0x3ff398 ]
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
Using Device Tree in place at 80f80000, end 80f85145
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.2 (tcmichals@tcmichals-RP829AV-ABA-d4790y) (gcc version 4.8.2 20130603 (prerelease) (crosstool-NG li3
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DT missing boot CPU MPIDR[23:0], fall back to default cpu_logical_map
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c08af000 s9792 r8192 d14784 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64768
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] allocated 524288 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 255MB = 255MB total
[ 0.000000] Memory: 251468k/251468k available, 10676k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05a2bfc (5739 kB)
[ 0.000000] .init : 0xc05a3000 - 0xc05d8640 ( 214 kB)
[ 0.000000] .data : 0xc05da000 - 0xc06485a0 ( 442 kB)
[ 0.000000] .bss : 0xc06485a0 - 0xc06a6538 ( 376 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000391] Calibrating delay loop… 548.86 BogoMIPS (lpj=2744320)
[ 0.049783] pid_max: default: 32768 minimum: 301
[ 0.050010] Security Framework initialized
[ 0.050113] Mount-cache hash table entries: 512
[ 0.054858] Initializing cgroup subsys memory
[ 0.054943] Initializing cgroup subsys blkio
[ 0.055074] CPU: Testing write buffer coherency:
[ 0.055129] ------------[ cut here ]------------
[ 0.055169] WARNING: at mm/vmalloc.c:128 vmap_page_range_noflush+0xe9/0x114()
[ 0.055183] Modules linked in:
[ 0.055208] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.2 #3
[ 0.055275] [] (unwind_backtrace+0x1/0x88) from [] (show_stack+0xb/0xc)
[ 0.055324] [] (show_stack+0xb/0xc) from [] (warn_slowpath_common+0x33/0x50)
[ 0.055357] [] (warn_slowpath_common+0x33/0x50) from [] (warn_slowpath_null+0xf/0x14)
[ 0.055389] [] (warn_slowpath_null+0xf/0x14) from [] (vmap_page_range_noflush+0xe9/0x114)
[ 0.055420] [] (vmap_page_range_noflush+0xe9/0x114) from [] (map_vm_area+0x1b/0x44)
[ 0.055447] [] (map_vm_area+0x1b/0x44) from [] (vmap+0x2f/0x44)
[ 0.055480] [] (vmap+0x2f/0x44) from [] (check_writebuffer_bugs+0x33/0xe8)
[ 0.055517] [] (check_writebuffer_bugs+0x33/0xe8) from [] (start_kernel+0x207/0x264)
[ 0.055545] [] (start_kernel+0x207/0x264) from [<8000807d>] (0x8000807d)
[ 0.055612] —[ end trace 1b75b31a2719ed1c ]—
[ 0.055647] failed, unable to map memory
[ 0.055647]
[ 0.056128] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.056422] Setting up static identity map for 0xc036a480 - 0xc036a4cc
[ 0.057764] Brought up 1 CPUs
[ 0.057787] SMP: Total of 1 processors activated (548.86 BogoMIPS).
[ 0.057801] CPU: All CPU(s) started in SVC mode.
[ 0.059070] devtmpfs: initialized
[ 0.126085] pinctrl core: initialized pinctrl subsystem
[ 0.126708] regulator-dummy: no parameters
[ 0.127305] NET: Registered protocol family 16
[ 0.128088] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.138898] OMAP GPIO hardware version 0.1
[ 0.147195] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.161237] bio: create slab at 0
[ 0.164097] SCSI subsystem initialized
[ 0.164494] usbcore: registered new interface driver usbfs
[ 0.164605] usbcore: registered new interface driver hub
[ 0.164885] usbcore: registered new device driver usb
[ 0.165760] omap_i2c 44e0b000.i2c: did not get pins for i2c error: -19
[ 0.166287] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.168586] DCDC1: at 1800 mV
[ 0.169816] vdd_mpu: 925 <–> 1325 mV at 1100 mV
[ 0.170929] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.172014] LDO1: at 1800 mV
[ 0.173087] LDO2: at 3300 mV
[ 0.174170] LDO3: at 3300 mV
[ 0.175253] LDO4: at 3300 mV
[ 0.175935] tps65217 0-0024: TPS65217 ID 0xf version 1.1
[ 0.176168] media: Linux media interface: v0.10
[ 0.176290] Linux video capture interface: v2.00
[ 0.176442] pps_core: LinuxPPS API ver. 1 registered
