Hi Guys ,
I have a beagle bone , when i connect my USB cable with BB , It blinks PWR Led once and nothing happens, but if i connect it to DC 5V Adapter, it works fine but i done get the USB to Ethernet interface.
I have tried formatting SD card and also replacing the cable,
Also, the 5V Adapter supply which i am giving is also from laptop USB, so i dont know what is wrong,
Is it a problem with the H/W, i.e. FTDI IC or something Else,
any help will be greatly appreciated .
Thanking You,
Gurinder Singh Gill
Hi Guys ,
Are you saying you have a USB -> DC Jack type plug? Have you tried a
different computer?
Yup USB → DC type. and yes I Have, but same as ever, also I own an Beagle bone black , thats works absolutely fine .
I have eliminated the FDI chip going bad , as in LINUX when i connect the Beagle Bone(White) it shows connecting as FTDI for a sec, and goes off .
Sounds like the board is damaged. I suggest that you request an RMA.
thanks for the tip Gerald but what exactly is a RMA ?
and if BB is damaged why can i still boot Linux using DC 5v Power supply ?
Gurinder
Returned Material Authorization. It is when you send the board in to be repaired for a Hardware issue. You request one, we send it, and then you send the board back.
You said the power LED blinks once. Is that not a true statement?
" I have a beagle bone , when i connect my USB cable with BB , It blinks PWR Led once and nothing happens, "
