Hi, in my beaglebone I tested Huawei K3765 , Huawei E353 and ZTE
MF626 3G USB dongles with success
Now I'm using Huawei E353 because it has antenna connector and more
reliable for a all-time-connected.
U can find K3765 or E353 on ebay unlocked for nice price.
It would be easier to get the modem working on the bone with ubuntu
http://elinux.org/BeagleBoardUbuntu#Demo_Image
Kind of plug an play, Only need to install ppp dialer apt-get install
ppp
After that it is recommend to disable the CD-ROM mode of the USB
dongle, for this u need to open a serial connection for example in
windows and type at^u2diag=256 enter or at^u2diag=0 enter , more
info about that search google "HUAWEI Disable CDRom Mode"
To test AT command on serial just write AT than enter And u should
receive OK if the serial connection is correct, if not try other
serial port..
After that u plug the dongle in bone and go on command line and type
dmesg
It will list the device pluged like this :
[254514.772777] usb 1-1.2: new high-speed USB device number 12 using
musb-hdrc
[254514.874784] usb 1-1.2: New USB device found, idVendor=12d1,
idProduct=1001
[254514.874834] usb 1-1.2: New USB device strings: Mfr=3, Product=2,
SerialNumber=0
[254514.874872] usb 1-1.2: Product: HUAWEI Mobile
[254514.874901] usb 1-1.2: Manufacturer: HUAWEI Technology
[254514.885585] option 1-1.2:1.0: GSM modem (1-port) converter
detected
[254514.886712] usb 1-1.2: GSM modem (1-port) converter now attached
to ttyUSB0
[254514.889588] option 1-1.2:1.1: GSM modem (1-port) converter
detected
[254514.890889] usb 1-1.2: GSM modem (1-port) converter now attached
to ttyUSB1
[254514.895496] option 1-1.2:1.2: GSM modem (1-port) converter
detected
[254514.896857] usb 1-1.2: GSM modem (1-port) converter now attached
to ttyUSB2
[254514.899147] scsi9 : usb-storage 1-1.2:1.3
[254515.915439] scsi 9:0:0:0: Direct-Access Vodafone Storage
(Huawei) 2.31 PQ: 0 ANSI: 2
[254515.930543] sd 9:0:0:0: Attached scsi generic sg0 type 0
[254515.938729] sd 9:0:0:0: [sda] Attached SCSI removable disk
If u get this ur on the good way
U have 3 serial ttyUSB0 , ttyUSB1 , ttyUSB2, and sda(microsd card)
ttyUSB0 is for the ppp dialer and ttyUSB2 is for AT command mode and
monitor (u can also send and receive SMS)
If u want to get into GPRS mode instead of 3G/UMTS u have to send an
AT command AT^SYSCFG=13,1,3FFFFFFF,1,2 for GPRS only or
AT^SYSCFG=14,2,3FFFFFFF,1,2 for 3G only (default)
GPRS is much slower and more ping but u have much more distance range
Need also to register a modem to network send AT+CPIN=xxxx on AT
command line where xxxx is ur PIN , u should receive OK that the modem
is registered at network.
Now u have to configure the pppd (must be installed first apt-get
install ppp)
I'm using the following command to activate my connection:
pppd /dev/ttyUSB0 921600 mtu 552 mru 552 modem crtscts dump
defaultroute noipdefault usepeerdns ktune noauth logfd 2 logfile /
pppd.log lock persist holdoff 1 maxfail 20 connect "/usr/sbin/chat -v
-f /etc/ppp/connect_script"
U have to edit the dialer script with command nano /etc/ppp/
connect_script
My script is this:
# chat script
ABORT 'NO CARRIER'
ABORT 'NO DIALTONE'
ABORT 'BUSY'
ABORT 'ERROR'
ABORT 'NO ANSWER'
'' 'ATZ'
OK 'AT&F'
OK 'ATQ0 V1 E1'
OK 'AT&D2 &C1'
OK 'AT+FCLASS=0'
OK 'ATS0=0'
# repalce internet.vodafone.pt with ur provider
OK 'AT+CGDCONT=1,"IP","internet.vodafone.pt"'
# make sure the dial number for ur operator data mode is *99#
OK 'ATDT*99#'
CONNECT ''
After u have this script with ur provider and correct dial number u
can use the pppd command to get connected as I said before.
U can also see the log of pppd to see if everything went allright
with command cat /pppd.log
Then u do an ifconfig and u will see ur new ppp connection with the IP
of mobile dongle.
U could also use sakis3G to get connected in a easier way
http://wiki.sakis3g.org/wiki/index.php?title=Sakis3G_installation
sakis3g connect APN="internet" APN_USER="" APN_PASS=""
USBDRIVER="option" MODEM="OTHER" OTHER="CUSTOM_TTY" CUSTOM_TTY="/dev/
ttyUSB0" SIM_PIN="xxxx"
Just repalce xxxx with pin and use ur APN provider ,user and pass
or u can use interactive mode type command sakis3G connect --
interactive
If u are using angstrom distribution on bone u will have more work to
do get it connected, a good start is
http://www.pandorawiki.org/USB_compatibility_list#HSDPA_.283G.29_Modems
u can see some help to get dongles working, just collect ideas an u
could have luck
Regards
