I was working with my Beagleboneblack
(debian image) then suddenly it went off and after that I connected the usb cable again but it didn't start. After that I connected the console cable to the computer but the output was just "ccccc...."
I don't know what should I do.
Re flash the eMMC or boot from the SD slot,
When I put the micro sd to the slot nothing happens and it still ....
how can I reflash the emmc
Put the sd card in
Press and hold the boot button
Plug in the power
Yes I did this all the leds 0000
This should work if you properly unzipped the image file and used disk imager to create the SD card
Thank you
But it's not my first time to flash the BBB But I don't know why it cant boot from the sd card on the serial debug port the output is just "ccccc"
CCCC means it cannot find a boot source. Not SD or eMMC. It could be you have a damaged card cage. Best option may be to get an RMA
