Hello everyone
My beagle bone black does not work. Had installed ubuntu 14.04 and as had many problems working with a server and serial ports I decided to install debian 7.5. My problem occurred when calculating the time of installation. I wait three minutes and believed that the installation process is ready and disconnect everything and took my TV, but the beagle did not work.
- Symptoms that has the beagle is as follows
–at Try to connect by USB power LED flashes only once and then off. and led others do nothing
–at Connect with external power (5V, 2.5A) power LED remains lit steadily, but not others led on. This also increases the temperature, the bottom of the plate is too hot.
What could it be? is successfully burned? or be a problem of bad flash?
Greetings and thanks
