Hi
I have an application that requires two BeagleBones (White) one of them master and the other slave… Is it possible to reboot/execute commands on the slave via the Master through the Serial port? Is Serial port the best way to do handshaking between the two BBs?
Serial communication is a good way to interface computers.
Is it the best? I can think of a lot of ways to interface computer boards.
I think you are talking about inventing a protocol for communication between devices.
Think about making the command structure easy to validate, and easy to parse.
Jody
“Best” would be subjective. Ethernet ? <— faster. UART <— possibly simpler. There is also at least I2C and SPI, but honestly can not think of a good reason to use either of these in place of the first two I mentioned. Maybe I2S too ? But I do not know much about I2S.
"Best" would be subjective. Ethernet ? <--- faster. UART <--- possibly
I agree with William: Ethernet might be simpler, faster??, better??? but
for sure much more versatile, because you can create multiple parallel
connections!
If you build a local network with several BB(B)'s and your (hopefully
Linux?)
Laptop, then you create a little Server farm with one System with human
interfaces and in your case two “headless servers”. And, for such systems
you find “_all_” information you need on the WWW.
Specifically:
- ssh login without password
- scp without password
- ssh tunnel without password
- mount distant file systems without password
- Cluster with 10'000 BB's (did anyone try this???)
- And last but not least: Shutdown another BB without password:
dw@dw-UX31E:~$ ssh root@1.2.3.4 -X shutdown -h now
(I tried, it worked, I had to restart my server@home, lucky for me, I was
@home.....)
HTH
