Beaglebord running Ubuntu - Networking problem
Hi everyone,
I have just installed ubuntu on my beagleboard (after getting really upset from Angstrom) and I cannot manage to have internet connection at all!
I need wireless connection, so first I configured the wpa_supplicant.conf according to the tutorial here
http://antipastohw.pbworks.com/w/page/27990127/Wi-Fi%20Setup%20Using%20Belkin%20F5D7050%20USB . It doesn’t work.
Then I tried the simple approach, listed on eLinux.org/BeagleBoardUbuntu for the wireless connectivity, but this fails too.
I cannot even get connected through ethernet (which I don’t want).
The error I’m getting is:
ioctl[SIOCDIWENCODEEXT]: Invalid argument
Failed to bring up wlan0
Does anyone know what I might be missing?
Thanks in advance.
Marina
So which usb wifi device are you using?
Can you show what you've set so far for wpa_supplicant.conf (minus
your password of course..)
Τη Δευτέρα, 9 Ιουλίου 2012 11:42:35 π.μ. UTC-4, ο χρήστης RobertCNelson έγραψε:
Hi everyone,
. It doesn’t work.
Then I tried the simple approach, listed on BeagleBoardUbuntu - eLinux.org for
Can you show what you’ve set so far for wpa_supplicant.conf (minus
your password of course…)
Robert Nelson
http://www.rcn-ee.com/
My WiFi adapter is the Ralink.
My wpa_supplicant.conf looks like this:
ap_scan=1
ctrl_interface=/var/run/wpa_supplicant
network={
ssid=“mySSID”
scan_ssid=0
proto=WPA
key_mgmt=WPA-PSK
psk=“myPwd”
pairwise=TKIP
group=TKIP
and I also changed the /etc/network/interfaces file to look like this:
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
wpa-driver wext
pre-up killall -q wpa_supplicant ; sleep 1 ; killall -q wpa_supplicant ; wpa_supplicant -B -Dwext -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
post-down killall -q wpa_supplicant
(that’s the wiki guide from here: Antipasto Hardware Wiki [licensed for non-commercial use only] / Wi-Fi Setup Using Belkin F5D7050 USB )
If I follow the guide from here: BeagleBoardUbuntu - eLinux.org
I still have the same problems…
Thanks!
Well, they only make about 20 different chipsets... So what usb/wifi
adatper do you actually have... "lsusb" would help out..
ap_scan=1
network={
        ssid="mySSID"
        scan_ssid=0
        proto=WPA
        key_mgmt=WPA-PSK
        psk="myPwd"
        pairwise=TKIP
        group=TKIP
     wpa-driver wext
seems a little over kill... any change with:
How about 3.4.x based kernel: (assuming precise-armhf, as you left
that info out..)
So with the Beagle connecting over ethernet..
wget http://rcn-ee.net/deb/precise-armhf/v3.4.4-x1/install-me.sh
/bin/bash install-me.sh
Τη Δευτέρα, 9 Ιουλίου 2012 2:14:26 μ.μ. UTC-4, ο χρήστης RobertCNelson έγραψε:
Well, they only make about 20 different chipsets… So what usb/wifi
adatper do you actually have… “lsusb” would help out…
ap_scan=1
network={
ssid=“mySSID”
scan_ssid=0
proto=WPA
key_mgmt=WPA-PSK
psk=“myPwd”
pairwise=TKIP
group=TKIP
wpa-driver wext
seems a little over kill… any change with:
that info out…)
So with the Beagle connecting over ethernet…
Robert Nelson
I am trying to rebuild the kernel again, because everything crashed before and nothing seemed to work!
Ethernet doesn’t work for me, I need WiFi accessibility…
Anyway, hopefully it won’t crash again, so I’ll give you the details about the adapter.
Thanks again!
