Belkin Wireless G with angstrom
Hello bellow is the boot up info. I have a keyboard a mouse and a
Belkin wireless G link connected to a CyberPower USB hub. The keyboard
and the mouse are working fine, but the wireless g is not getting
recognized. If anyone could provide some help in getting this
connected I would greatly appreciate it.
For background I have attempted been following the wiki link below and
have attempted all of the listed techniques for getting the wireless
to work.
http://code.google.com/p/beagleboard/wiki/HowToGetAngstromRunning
On another Note I have found it odd that the commands available in
the terminal over serial are different than the commands available in
Angstrom. I was wondering if there was a way to correct this....for
example ifconfig works over serial but does not work while logged into
angstrom, whether root or user.
Any Help is appreciated Thanks!
Texas Instruments X-Loader 1.4.2 (Sep 8 2008 - 22:38:13)
Booting from nand
U-Boot 1.3.3 (Jul 10 2008 - 16:33:09)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 Beagle Board + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Audio Tone on Speakers ... complete
reading uImage
2230884 bytes read
## Booting kernel from Legacy Image at 80300000 ...
   Image Name: Angstrom/2.6.27/beagleboard
   Data Size: 2230820 Bytes = 2.1 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................
... done, booting the kernel.
Linux version 2.6.27-omap1 (koen@dominion) (gcc version 4.2.1) #1 Sun
Jan 4 19:3
4:45 CET 2009
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=00c5387f
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430 ES3.0
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
CPU0: L1 I VIPT cache. Caches unified at level 2, coherent at level 3
CPU0: Level 1 cache is separate instruction and data
CPU0: I cache: 16384 bytes, associativity 4, 64 byte lines, 64 sets,
      supports RA
CPU0: D cache: 16384 bytes, associativity 4, 64 byte lines, 64 sets,
      supports RA WB WT
CPU0: Level 2 cache is unified
CPU0: unified cache: 262144 bytes, associativity 8, 64 byte lines, 512
sets,
      supports WA RA WB WT
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
32512
Kernel command line: console=ttyS2,115200n8 console=tty0 root=/dev/
mmcblk0p2 roo
tdelay=2 rootfstype=ext3 video=omapfb:vram:2M,vram:4M
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 512 (order: 9, 2048 bytes)
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
console [tty0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 125084KB available (4128K code, 372K data, 172K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1,
Nodes=1
Calibrating delay loop... 491.57 BogoMIPS (lpj=1921024)
Mount-cache hash table entries: 512
Initializing cgroup subsys devices
CPU: Testing write buffer coherency: ok
net_namespace: 488 bytes
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP DMA hardware revision 4.0
USB: No board-specific platform config found
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, musb-dma, host, debug=0
musb_hdrc: USB Host mode controller at d80ab000 using DMA, IRQ 92
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Bluetooth: Core ver 2.13
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 244
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
omapfb: using mode 1024x768@60
omapfb: configured for panel omap3beagle
omapfb: DISPC version 3.0 initialized
Console: switching to colour frame buffer device 128x48
omapfb: Framebuffer initialized. Total vram 6291456 planes 2
omapfb: Pixclock 48000 kHz hfreq 40.5405 kHz vfreq 51.3 Hz
Serial: 8250/16550 driver4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
usb 1-1: new high speed USB device using musb_hdrc and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 1-1.1: new high speed USB device using musb_hdrc and address 3
usb 1-1.1: configuration #1 chosen from 1 choice
hub 1-1.1:1.0: USB hub found
hub 1-1.1:1.0: 3 ports detected
usb 1-1.3: new high speed USB device using musb_hdrc and address 4
usb 1-1.3: configuration #1 chosen from 1 choice
usb 1-1.4: new low speed USB device using musb_hdrc and address 5
usb 1-1.4: configuration #1 chosen from 1 choice
usb 1-1.1.2: new low speed USB device using musb_hdrc and address 6
usb 1-1.1.2: configuration #1 chosen from 1 choice
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver zd1211rw
usbcore: registered new interface driver rndis_wlan
usbcore: registered new interface driver zd1201
usbcore: registered new interface driver rtl8187
usbcore: registered new interface driver rt2500usb
usbcore: registered new interface driver rt73usb
usbcore: registered new interface driver prism54usb
i2c /dev entries driver
input: triton2-pwrbutton as /class/input/input0
triton2 power button driver initialized
Driver 'sd' needs updating - please use bus_type methods
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB
1,8V 16-bi
t)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on "omap2-nand":
0x00000000-0x00080000 : "X-Loader"
0x00080000-0x00260000 : "U-Boot"
0x00260000-0x00280000 : "U-Boot Env"
0x00280000-0x00680000 : "Kernel"
0x00680000-0x10000000 : "File System"
usbmon: debugfs is not available
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
twl4030_rtc twl4030_rtc: Power up reset detected.
twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Bluetooth: HCI USB driver ver 2.10
usbcore: registered new interface driver hci_usb
Bluetooth: Broadcom Blutonium firmware driver ver 1.2
usbcore: registered new interface driver bcm203x
Bluetooth: Digianswer Bluetooth USB driver ver 0.10
usbcore: registered new interface driver bpa10x
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
Registered led device: beagleboard::usr0
Registered led device: beagleboard::usr1
Registered led device: beagleboard::pmu_stat
input: Logitech Optical USB Mouse as /class/input/input1
input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-
musb_hdrc-1.4
input: Apple, Inc Apple Keyboard as /class/input/input2
input: USB HID v1.11 Keyboard [Apple, Inc Apple Keyboard] on usb-
musb_hdrc-1.1.2
input: Apple, Inc Apple Keyboard as /class/input/input3
input: USB HID v1.11 Device [Apple, Inc Apple Keyboard] on usb-
musb_hdrc-1.1.2
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.17.
usbcore: registered new interface driver snd-usb-audio
ASoC version 0.13.2
OMAP3 Beagle SoC init
TWL4030 Audio Codec init
asoc: twl4030 <-> omap-mcbsp-dai mapping ok
ALSA device list:
  #0: omap3beagle (twl4030)
oprofile: using arm/armv7
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: L2CAP ver 2.11
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.10
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ThumbEE CPU extension supported.
Power Management for TI OMAP3.
SmartReflex driver initialized
Disabling unused clock "sr2_fck"
Disabling unused clock "sr1_fck"
Disabling unused clock "mcbsp_fck"
Disabling unused clock "mcbsp_ick"
Disabling unused clock "gpt2_ick"
Disabling unused clock "gpt3_ick"
Disabling unused clock "gpt4_ick"
Disabling unused clock "gpt5_ick"
Disabling unused clock "gpt6_ick"
Disabling unused clock "gpt7_ick"
Disabling unused clock "gpt8_ick"
Disabling unused clock "gpt9_ick"
Disabling unused clock "wdt3_ick"
Disabling unused clock "wdt3_fck"
Disabling unused clock "gpio2_dbck"
Disabling unused clock "gpio3_dbck"
Disabling unused clock "gpio4_dbck"
Disabling unused clock "gpio5_dbck"
Disabling unused clock "gpio6_dbck"
Disabling unused clock "gpt9_fck"
Disabling unused clock "gpt8_fck"
Disabling unused clock "gpt7_fck"
Disabling unused clock "gpt6_fck"
Disabling unused clock "gpt5_fck"
Disabling unused clock "gpt4_fck"
Disabling unused clock "gpt3_fck"
Disabling unused clock "gpt2_fck"
Disabling unused clock "gpt1_ick"
Disabling unused clock "wdt1_ick"
Disabling unused clock "wdt2_ick"
Disabling unused clock "wdt2_fck"
Disabling unused clock "gpio1_dbck"
Disabling unused clock "gpt1_fck"
Disabling unused clock "cam_ick"
Disabling unused clock "cam_mclk"
Disabling unused clock "des1_ick"
Disabling unused clock "sha11_ick"
Disabling unused clock "rng_ick"
Disabling unused clock "aes1_ick"
Disabling unused clock "ssi_ick"
Disabling unused clock "mailboxes_ick"
Disabling unused clock "gpt10_ick"
Disabling unused clock "gpt11_ick"
Disabling unused clock "i2c_ick"
Disabling unused clock "mcspi_ick"
Disabling unused clock "hdq_ick"
Disabling unused clock "mspro_ick"
Disabling unused clock "mmchs_ick"
Disabling unused clock "des2_ick"
Disabling unused clock "sha12_ick"
Disabling unused clock "aes2_ick"
Disabling unused clock "icr_ick"
Disabling unused clock "pka_ick"
Disabling unused clock "ssi_ssr_fck"
Disabling unused clock "hdq_fck"
Disabling unused clock "mcspi_fck"
Disabling unused clock "i2c_fck"
Disabling unused clock "mspro_fck"
Disabling unused clock "mmchs_fck"
Disabling unused clock "gpt11_fck"
Disabling unused clock "gpt10_fck"
Disabling unused clock "iva2_ck"
Disabling unused clock "dpll5_ck"
Disabling unused clock "dpll4_m6x2_ck"
Disabling unused clock "dpll4_m5x2_ck"
Disabling unused clock "dpll3_m3x2_ck"
Disabling unused clock "sys_clkout1"
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:01
UTC (946684
801)
Waiting 2sec before mounting root device...
mmc0: host does not support reading read-only switch. assuming write-
enable.
mmc0: new high speed SD card at address 0007
mmcblk0: mmc0:0007 SD02G 1955840KiB
mmcblk0: p1 p2
kjournald starting. Commit interval 5 seconds
EXT3-fs warning: maximal mount count reached, running e2fsck is
recommended
EXT3 FS on mmcblk0p2, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem).
Freeing init memory: 172K
udevd version 124 started
end_request: I/O error, dev mtdblock0, sector 0
Buffer I/O error on device mtdblock0, logical block 0
end_request: I/O error, dev mtdblock0, sector 8
Buffer I/O error on device mtdblock0, logical block 1
end_request: I/O error, dev mtdblock0, sector 16
Buffer I/O error on device mtdblock0, logical block 2
end_request: I/O error, dev mtdblock0, sector 24
Buffer I/O error on device mtdblock0, logical block 3
NET: Registered protocol family 10
      > > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyS2
Angstrom 2009.X-test-20090102 beagleboard ttyS2
beagleboard login:
*>>>On another Note I have found it odd that the commands available in
angstrom, whether root or user.<<<*
---> I would guess that the PATH environment variable is different when you
are logging from serial terminal & otherwise. Are you logging on with the
same user in both modes... In the mode where ifconfig is not working try to
give its absolute path i.e. /*sbin*/*ifconfig* & see if that works...
-Nitin
Thanks I forgot about that I got it fixed with a PATH=$PATH:/sbin at
the command prompt. That is odd that there are two separate terminals
available. Thanks for the help, hopefully someone knows how to get the
wireless fixed. I still do not know why it is not being recognized.
Thanks.
Thanks.
Well probably its not two seperate terminals but the difference is coming from what startup script that is setting the path variable. Due to the different init level your sytem is in while logged in from terminal (3, I assume) & GUI console (5, graphical). Under /etc/init.d/ directories there are folders for each init level. The scripts under these folders have a name starting with capital S followed by a number which defines the sequence in which the scripts are executed (the capital S is important as the system recognizes the script as startup script this way, similarly there are scripts with a capital K and a sequence no… The ones with a K are fired when the system moves out of that init level). I am guessing this to be the case, so anyone please correct me if this is not the case. Check the directory /etc/init.d/rcS/… as these are fired at startup…
-Nitin
So this is interesting...below references are to images are found on
http://www.angstrom-distribution.org/demo/beagleboard/
This is wlan0 for belkin wirelessg Model FSD7050 in Angstrom. For me
at least these are the results so far..
With the uImage-2.6.26-r65-beagleboard.bin
         ---wlan0 does not show up, nor does it work ever
         +++Gui angstrom works great on HD monitor
         +++Mouse and keyboard show up and work great
With the uImage-2.6.27-r12-beagleboard.bin
         +++wlan0 shows up and works with the configuration from the
bottom of...
         ---Gui angstrom does not show up on the HD monitor
         +++Mouse and keyboard show up but are not responsive
With the uImage-2.6.28-r12-beagleboard.bin
bottom of...
-------In Summary one image that I have seen to work with the GUI does
not recognize the belkin wireless g, and the images that recognize the
belkin wirless g to not have GUI output to monitor. Has anybody else
had these results, or know how to get atleast one of these images to
do both?
