Thank you for all the help!
I have finally been able to get this array constructed by a user space C program into the external DDR ram, and access the array directly from PRU0 using uio_pruss! I wanted to give an update on what I did for anyone else who might try to do something similar in the future.
TJF and the others were right, I could not find an easy way to do this using rproc, but with uio_pruss it is fairly straight forward. While the suggestions made to help me get this going were surely valid, I found what seemed to be the simplest way for me using the example PRU_memAccess_DDR_PRUsharedRAM found in the am335x_pru_package which I just cloned from here.
I was unable to do this before because I did not set up my beaglebone for uio_pruss correctly, and would always get errors when using commands like prussdrv_open(). But from the suggestions in this post I was able to figure out what I was doing wrong, and got uio_pruss set up properly so that I could run this example. The example uses a c script to mmap() a block of memory in DDR and stores 3 values in the first 3 addresses of the mapped memory, then it programs the pru with an assembly file that is compiled with pasm, to simply configure OCP master port, configure one programmable pointer to point at the DDR memory where the 3 values are, and configure another programmable pointer to point to the pru’s shared RAM. The pru loads in the three values into 3 of its 32 registers, and then places them in the first 3 address of its 12kB shared RAM. Then the pru halts after interrupting the host c program that it finished, and the c program checks the 3 registers in the shared RAM to see if they are the same values that it originally stored in DDR RAM.
I was able to modify this example to mmap() a larger block of memory, and store the ~300,000 integer bytes into the DDR registers, then have the PRU check all of them and confirm that it is as it should be, then it loops and does what it needs to do set its GPIOs appropriately at very high frequency! It works great!
Some things I had to do to set up the executable:
- set up Beaglebone to enable uio_pruss
-(This worked on several different linux images that I tried it on, but currently I’ve installed 4.4.88-ti-r125) in the uEnv.txt file, I added this line “dtb=am335x-boneblack-emmc-overlay.dtb”, and uncommented these lines “disable_uboot_overlay_video=1 disable_uboot_overlay_audio=1” but most importantly comment out “#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-4-TI-00A0.dtbo” and uncomment “uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo”. Then after rebooting you should see this if you enter lsmod | grep pru :
uio_pruss 4629 0
uio 11100 2 uio_pruss,uio_pdrv_genirq
pru_rproc 15879 0
pruss 12346 1 pru_rproc
pruss_intc 9009 1 pru_rproc
-If there are any GPIOs that you want to give to the PRU, find the pins that will work using the BBB reference manual, and simply config-pin them for use by pru. for example " config-pin P9_31 pruout ", check that it worked with “config-pin -q P9_31”, it should print “P9_31 Mode: pruout”
set up everything for the make files in the am335x_pru_package to work: (this only needs to be done once)
This is example tutorial was very helpful, but I had to do a few things slightly differently:
-before anything, type " export CROSS_COMPILE= "
-cd to /am335x_pru_package/pru_sw/app_loader/interface and enter " make ". This creates 4 files - libprussdrv.a libprussdrvd.a libprussdrvd.so libprussdrv.so, copy them all into /usr/lib and enter " ldconfig "
-cd to /am335x_pru_package/pru_sw/utils/pasm_source and enter " source ./linuxbuild " . This creates the pasm executable one directory up in /am335x_pru_package/pru_sw/utils , copy pasm into /usr/bin , and make sure it works by just typing " pasm " with no arguments. If it’s done correctly you will get a usage instruction statement because no arguments were given.
now that the uio_pruss is working, and am335x_pru_package has been correctly “built”, the examples can be used to do all sorts of cool stuff by modifying .c scripts, .p (assembly) scripts, and .hp (assembly header) scripts. To compile an example or modified example do this:
-cd /am335x_pru_package/pru_sw/example_apps and run first “make clean” and then “make”. All the examples will be compiled.
-inside /am335x_pru_package/pru_sw/example_apps/bin are all the compiled binary files created from each example’s assembly code. Copy the one you want into /am335x_pru_package/pru_sw/example_apps//obj
-compile the .o and .bin files within /obj by linking with a command like "gcc .o -L…/…/…/app_loader/lib -lprussdrv -lpthread -o myexecutable.out
-This makes an executable myexecutable.out in the same /obj folder, which is ready to run with ./myexecutable.out !!! All done!
If anyone wants to know more about the ways I modified the .c script to mmap() a larger DDR memory block, or the .p script which tells the pru how to deal with a much larger memory block, I can also post code about that stuff as well.
I hope this is helpful to any beginners out there like me!
Thanks again for the help,
Evan
