Best way to test / transfer BBB Wireless custom Kernel
I have compiled Roberts kernel (https://github.com/RobertCNelson/bb-kernel) and now trying to figure out how to install the new kernel and the dtb file in order to test it. I know most tutorials say to use tftp and ethernet however the black does not have ethernet.
What is the preferred method of doing this?
I have a UART connection, however if think to do this I would have to compile the SPL too? Which means I would have to compile uboot, transfer the SPL, then execute uboot from memory, then transfer the uimage and dtb then boot?
I have not tried this, thinking that there might be an easier way to do this?
Thanks!
Riley
Have you set up the USB Network connection from a PC to the BBBW?
You can see what Mark Yoder did in his exercises for a couple of options:
https://elinux.org/EBC_Exercise_08_Installing_Development_Tools_4.4
Cheers,
Jon
Cheers,
Jon
Take the microSD from the board, plug into your linux pc and run:
./tools/install_kernel.sh
(you'll have to update system.sh to specify your drive name..)
Thanks for both answers! Is there a real reason to update uboot? I am just enabling some stuff I needed in the kernel so I am not sure that is really needed?
Thanks again for your help.
Riley
