What I have:
I have a 4-bit logic level converter.
I have a BeagleBone Black running ubuntu, not angstrom. (BBB)
I am using the PyBBIO library for serial communication on the BBB.
I have the Device Tree Overlay- I have an Arduino Uno.
What I can/cannot do: -
I am able to send from the Arduino to the BBB.
When I attempt to send from the BBB to the Arduino I cannot.
I am able to send from an Tx pin on the BBB to an Rx pin on the BBB.
This is over a wire connecting the two together.
I have also checked the output of the Tx pin with an Oscilloscope and it is correct.
This is true on both sides of the logic level converter.- I cannot send from the Arduino Rx pin from the Arduino Tx pin.
This again is over a wire.
I do not have the USB plugged in.
What I think: -
I think I’m having some sort of problem on my Arduino.
I have the ‘L’ LED blinking in my test program and eventually this stops.
I believe the program is eventually crashing but I am unsure why.
I was wondering if someone had any insight to what my problem could be? I am not sure what is happening and I can post any code segments if they would be beneficial.
Thanks!
