Bitbake build failure of Angstrom
I am attempting to manually rebuild the BeagleBoard validation image
using bitbake.
For this, I used the revision found in /etc/angstrom-version of an
image I built with Narcissus. The OE revision I used referring to the
above version file is: a1f31c757d2514e946737d60789c6f9f05ce38eb (Which
happens to be my fix for GPIO)
Now, when I run a "bitbake beagleboard-validation-gnome-image -k ",
below is the output showing that there are build failures with
libgbod, libnet-dbus-perl. The build did not complete (some 40 tasks
short).
A question that arises is, if Narcissus could build an image with this
tag without failures, why couldn't bitbake?
Here is a build log:
Why are you using -k ?
Hi Koen,
Nice to hear from you.
You're still not answering my question :slight_smile:
Hi Koen,
