I try to compile Angstrom with http://www.angstrom-distribution.org/building-angstrom
MACHINE=beagleboard ./oebb.sh config beagleboard
MACHINE=beagleboard ./oebb.sh update
MACHINE=beagleboard ./oebb.sh bitbake virtual/kernel
but know I want to have rootfs image, U-boot, MLO
So I tried this :
MACHINE=beagleboard ./oebb.sh bitbake console-image
but I have this error :
ERROR: Task 1525 (/home/mum/OE/setup-scripts/sources/openembedded-core/meta/recipes-core/netbase/netbase_4.47.bb, do_fetch) failed with exit code ‘1’
When I look at netbase_4.47.bb there is no do_fetch … just do_install.
FYI, I commented the line " INHERIT += “rm_work” " in conf/local.conf
Looking forward for help,
Jerome
Why not just source your OE env file so you only have to type
bitbake MYCOMMANDHERE
So I tried this :
ERROR: Task 1525
do_fetch) failed with exit code '1'
When I look at netbase_4.47.bb there is no do_fetch ... just do_install.
FYI, I commented the line " INHERIT += "rm_work" " in conf/local.conf
bitbake -c cleansstate netbase
bitbake -f netbase
or bitbake -c cleansstate netbase
bitbake -c fetch netbase
bitbake netbase
Jerome
-- To join: http://beagleboard.org/discuss
To unsubscribe from this group, send email to:
beagleboard+unsubscribe@googlegroups.com
Frequently asked questions: http://beagleboard.org/faq
Some packages take a couple tries to fetch. Especially when you're trying to fetch tons of packages at once. Occasionally you will have a connection issue or 10.
HTH
So I tried this :
ERROR: Task 1525 (/home/mum/OE/setup-scripts/sources/openembedded-core/meta/recipes-core/netbase/netbase_4.47.bb, do_fetch) failed with exit code '1'
Look through the archives - this was discussed a lot last week.
Basically, the needed file has been removed from the debian site that hosted it
You can get what you need from the Yocto mirror (http://downloads.yoctoproject.org/mirror/sources/)
So I tried this :
ERROR: Task 1525
hosted it
Hopefully they get away from the Debian mirrors since they seem to cause lots of fetch issues.
If it was sorted out last week why has no patch been pushed to eliminate the problem? Seems like it would have not only been quick but easy to solve and get it pushed. But hey many things dont make sense to me in OE
If you read when you run MAHCINE=beagleboard ./oebb.sh config beagleboard.
It spits out a message you now have a file in ~/.oe/* to source
such as
. ~/.oe/oe_environment
and now you can just run
bitbake WhatIWantToBuild
So when you are in /setup-scripts, source the file.
