Bitbake error that I am unsure on how to fix.
Morning all,
I am attempting to build the qt-embedded sdk, built using bitbake meta-
toolchain-qt from the org.openembedded.dev branch as it would seem it
is not available on the stable one. It has been building for hours and
has been interrupted half way through with the error here. I am really
not sure on how to fix this, does anyone have any ideas what I need to
do?
Thanks for any help.
NOTE: Running task 1569 of 2452 (ID: 508, /home/testdev/oe/
openembedded/recipes/binutils/binutils-cross-sdk_2.18.50.0.7.bb,
do_package)
objcopy:/home/testdev/oe/tmp-dev/work/i686-armv7a-sdk-angstrom-linux-
gnueabi/binutils-cross-sdk-2.18.50.0.7-r7.1/image/usr/local/angstrom/
arm/i686-linux/arm-angstrom-linux-gnueabi/lib/stoVELXG/archive.o:
cannot create debug link section `/home/testdev/oe/tmp-dev/work/i686-
armv7a-sdk-angstrom-linux-gnueabi/binutils-cross-sdk-2.18.50.0.7-r7.1/
image/usr/local/angstrom/arm/i686-linux/arm-angstrom-linux-gnueabi/
lib/.debug/libbfd.a': Invalid operation
arm/i686-linux/arm-angstrom-linux-gnueabi/lib/stesnFlO/dis-buf.o:
lib/.debug/libopcodes.a': Invalid operation
arm/lib/str3X3D2/regex.o: cannot create debug link section `/home/
testdev/oe/tmp-dev/work/i686-armv7a-sdk-angstrom-linux-gnueabi/
binutils-cross-sdk-2.18.50.0.7-r7.1/image/usr/local/angstrom/arm/
lib/.debug/libiberty.a': Invalid operation
NOTE: Couldn't find shared library provider for libc.so.6
NOTE: Couldn't find shared library provider for libm.so.6
ERROR: QA Issue with binutils-cross-sdk: non debug package
contains .debug directory: binutils-cross-sdk path /work/i686-armv7a-
sdk-angstrom-linux-gnueabi/binutils-cross-sdk-2.18.50.0.7-r7.1/install/
binutils-cross-sdk/usr/local/angstrom/arm/i686-linux/arm-angstrom-
linux-gnueabi/lib/.debug/libbfd.a
linux-gnueabi/lib/.debug/libopcodes.a
ERROR: QA run found fatal errors. Please consider fixing them.
ERROR: Error in executing: /home/testdev/oe/openembedded/recipes/
ERROR: Exception:<type 'exceptions.SystemExit'> Message:1
ERROR: Printing the environment of the function
