Bitbake/OE bitbake.conf Bug
I just upgraded to git head, and I encountered some problems. I fixed most of these by updating/porting my local overlay versions of local.conf and bitbake.conf to match the ones distributed with OE. When I tried to build again I got the following error
bitbake console-image
ERROR: Openembedded’s config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Error, Your PACKAGE_ARCHS field contains duplicates. Perhaps you set EXTRA_PACKAGE_ARCHS twice accidently through some tune file?
The culprit (in conf/bitbake.conf) is
PACKAGE_ARCHS = “all any noarch ${TARGET_ARCH} ${PACKAGE_EXTRA_ARCHS} ${MACHINE}”
Removing ${PACKAGE_EXTRA_ARCHS} fixes the error
Does this mean that there is a bug in the bb.conf file distributed with OE, or have I missed something
John
ERROR: Openembedded's config sanity checker detected a potential
misconfiguration.
Error, Your PACKAGE\_ARCHS field contains duplicates\. Perhaps you set
PACKAGE_ARCHS = "all any noarch ${TARGET_ARCH} ${PACKAGE_EXTRA_ARCHS}
${MACHINE}"
That's not the culprit. It sounds like you have a copy of
beagleboard.conf in your overlay that still has PACKAGE_EXTRA_ARCH
set:
http://gitweb.openembedded.net/?p=openembedded.git;a=commitdiff;h=a1825f04c3b8b98a66ae402e99fd40ff2be59c82
regards,
Koen
misconfiguration.
${MACHINE}”
That’s not the culprit. It sounds like you have a copy of
set:
Yip, that was the problem. Thanks a lot
John
