bitbaked u-boot.bin can't be loaded
Hi there,
I just did a
$ bitbake x-loader
$ bitbake u-boot
without any errors in my angstrom-2010.x.
Afterwards I copied MLO and u-boot.bin onto the first partition of SD-Card and my BeagleBoard is stuck with this messages:
Hi there,
I just did a
$ bitbake x-loader
$ bitbake u-boot
Texas Instruments X-Loader 1.5.1 (Apr 25 2012 - 16:45:59)
Beagle Rev C4
Reading boot sector
Loading u-boot.bin from mmc
If i use an older u-boot.img, everything works as expected:
Beagle Rev C4
Reading boot sector
U-Boot 2011.06 (Oct 05 2011 - 17:30:32)
OMAP3530-GP ES3.1, CPU-OPP2, L3-165MHz, Max CPU Clock 720 mHz
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Beagle Rev C4
I erased my nand via "nand erase.chip" so there should be no old residues in
the flash.
Did I miss something?
I suspect you might have an SD card formatting issue. My hack is to
do make sure MLO includes a configuration header and copy it to the
MBR of the SD card, making sure that the directory entries of the
first partition don't matter because they are easy to get wrong. [1]
[1] http://groups.google.com/group/x-loader/msg/1c110a2f8512e3ff
Hi there,
I just did a
$ bitbake x-loader
$ bitbake u-boot
Beagle Rev C4
Reading boot sector
Ignore my commend below. I didn't realize that MLO was executing fine
for you and it was just u-boot.bin that was failing. This is indeed a
bit odd. I'll try this on Monday.
it is a bit strange coz I did the similar operation as you did to copy MLO and u-boot.bin
into the first partition of SD. all work fine. which version of your openembedded you
were used? is it openembedded-2011.3 maintenance or the one from angstrom repository?
hi…
did u find the cause for the issue ? did u resolve it ??
please shed somelight on this thread somebody…
