I am trying to run the blinkled.js program from the Cloud9 IDE. When I run it in Cloud9 on the B^3, nothing happens to my led. I have Ground going to the resistor, the resistor going to the short connector on the led and the long connector of the led going to pin 13. If I take the same program and run it by typing node blinkled.js at the BASH prompt, I get an error message:
error b.pinmode at line 6
object # has no method pinmode
error message:
object #<object> has no method pinmode
I was able to figure it out.
If you look at analog.js, it uses the same pin for LED’s. To turn the LED off/on, you need to write b.analogWrite(outputPin, value);.
Seeing that the analog.js program was working perfectly, I tried it on the blinked.js and it worked!
In blinked.js under the toggle function, replace the “b.digitalWrite(ledPin, state);” with “b.analogWrite(outputPin, value);” and your LED’s should both start blinking.
