Bluetooth chipsets
Hi all,
I am new to Beagle Board so m learning few things.Its quite
interesting.
I have read that Beagle Board supports Bluetooth.I wanted to know
whether we can have embedded Bluetooth chips with the board when we
order it.
thanks,
prashanth
Correct me if I'm wrong, but I think you need hardware added to the
beagle for bluetooth.
Typically you can get usb bluetooth or serial bluetooth modules for
this purpose.
Sean
There are no options for embedded bluetooth devices on the BeagleBoard.
From what I have read the bluetooth is intended to be added using USB
modules. The same is true for Ethernet and WiFi. That's not a bad
idea actually, as long as the drivers are available to make USB work
well. But choose your modules well. I have seen some really crappy
ones on PCs, but that may well be the software rather than the
hardware.
Rick
