I recently bought beaglebone. I tested the board with kernel 3.1 and debian rootfile system.
I liked to test bluetooth in beaglebone. I compiled the kernel and built sucessfully by enabling necessary drivers for bluetooth.
When i plugged in bluetooth dongle in USB
I got the following error message
[ 3245.513220] Bluetooth: hci0 command tx timeout
Is anybody got successful in using bluetooth in beagleboard
When i searched in net about this error, i found it was due to the bug in the kernel. Is there anyway to solve this
I found much difficulty in getting the kernel source for beaglebone.
Where can i get the kernel 2.6 source for beaglebone
rootfile system.
Which 3.1 kernel? Can you provide the .config? If it was properly
enabled, it should work, so best to start with confirming the kernel
really was configured properly.
What dongle did you purchase/use?
in a local angstroem build: where do I have to execute the menuconfig skript to configure the kernel.
In buildroot environment this is clear. But how to proceed in angstroem … open embedded.
