I have a beagleboard and I need to write a new ASoC driver based on
the resident TWL4030 driver as a template.
The question is where should I declare that I'll use additionaly the
McBSP1 port (McBSP2 is used by TWL4030) for connection to my new codec
device?
Is there a startup/setup somewhere whereas the board resident devices
and interfaces are being declared declared and allocated at boot time?
Or is it a document that describes some fundamentals of kernel booting
and interface initialization at boot time for the beagleboard
distributions?
I knew from other architectures (avr) something like setup.c but
apparently here we have something different and since I'm new to this
I could use some help here too.
In case you need something more advanced look in either u-boot- or the
Linux-sources.
In order to get going x-loader source is though a great starting point
Linux-sources.
Whops - I did only read the last message - not the full thread.
Apparently this thread started out with a request for some ASoC help, which
nobody has answered.
Hence this new post from Sv1Eia in order to check if anybody could help.
