Bone Kernel Rebuild instructions
I’ve been able to rebuild a Beaglebone Angstrom kernel with the instructions here http://www.chalk-elec.com/?p=1605 and here http://www.youtube.com/watch?v=HJ9nUqYMjqs&list=PLF4A1A7E09E5E260A. The instructions are basically the same and are relatively recent.
However, when changing system.sh to “- uncomment line BUILD_UIMAGE=1”, I find that " BUILD_UIMAGE=1" is not in the file. I make the other changes OK (to /dev/sdb, etc.) and build.
When I finish with the “./tools/rebuild.sh”, there is no way to load it onto the card because the “./tools/load_uImage.sh” does not exist.
Are there new instructions to do this step? The authors of the above have not replied to my questions.
James
BTW, I get the following error when I tried to run “./tools/install_kernel.sh”
./tools/install_kernel.sh: line 219: syntax error near unexpected token }' ./tools/install_kernel.sh: line 219: }’
What is the cause? How do I fix it?
James
**** changes I made to system.sh ****
uncommented: CC=arm-linux-gnueabi-
changed folder to: LINUX_GIT=/home/user/bb/linux-stable/
uncommented: ZRELADDR=0x80008000
uncommented: MMC=/dev/sdb
added: BUILD_UIMAGE=1
"./tools/install_kernel.sh"
./tools/install_kernel.sh: line 219: syntax error near unexpected token `}'
./tools/install_kernel.sh: line 219: ` }'
I fixed it 3 days ago:
James
This is already taken care by un-selecting the "ZRELADDR" and running
Thanks Robert.
So to complete my build do I have to repeat both of these steps?
git clone git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git
git clone git://github.com/RobertCNelson/linux-dev.git
James
Why "repeat" ? once it's initially cloned, it's on your harddrive...
from linux-dev directory, just
git checkout master -f
git branch -D tmp || true
git pull
git checkout origin/am33x-v3.2 -b tmp
./build_kernel.sh
Thanks for that, install_kernel.sh is writing the kernel to the SD card now.
When the card boots, I get a small penguin on the top left corner of the screen. What else do I have to do to get it back booting like a Beaglebone again, with networking, flashing LEDs, serial, etc?
James
Hello when try to flash sd card, I see this:
mkimage: Write error on /home/user/beaglebone/linux-dev/deploy/disk/uImage: No space left on device
Well that error tells you the pretty obvious issue, you have no more space on your disk.
