Bonescript analogRead problem
I’ve been having problems when doing a lot of bonescript analogRead calls successively. For example this code loops through about 7 times and then crashes:
var b = require(‘bonescript’);
var count=0;
while (true){
console.log(count++);
a1=b.analogRead(‘P9_36’);
a2=b.analogRead(‘P9_33’);
a3=b.analogRead(‘P9_35’);
a4=b.analogRead(‘P9_37’);
This is the program output, followed by the error message:
0
1
2
3
4
5
6
fs.js:481
var r = binding.read(fd, buffer, offset, length, position);
Error: EAGAIN, resource temporarily unavailable
at Object.fs.readSync (fs.js:481:19)
at Object.fs.readFileSync (fs.js:315:28)
at Object.exports.readAIN (/usr/local/lib/node_modules/bonescript/src/hw_capemgr.js:351:30)
at Object.f.analogRead (/usr/local/lib/node_modules/bonescript/src/index.js:266:19)
at Object. (/var/lib/cloud9/analogread2.js:8:10)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
Also tried this:
I tried doing a function callback and then assigning the value within the callback. This code, for example:
var a1=0;
while (true){
b.analogRead(‘P9_36’,assignValue);
function assignValue(x){a1=x.value;}
console.log(a1);
But… it doesn’t work. The output is just:
0
0
0
0
ad nauseum.
I have checked the x.value directly and it is a non zero number, but for some reason the a1 doesn’t get assigned the x.value number even though a1 is global.
Any suggestions?
