Thanks for the suggestion! I actually made it work using a different mechanism.
Once I saw your message about there being no way to connect the variables in loop with those in the web responder it broke me out of the mode of thinking I must be doing something really dumb and got me looking for another solution. I looked up the timer you mentioned but while doing my scratching about I discovered I at least got a copy of all the variables in the web responder and that it was possible to update the hardware. The hardware itself is certainly shared. So I split the hardware handling between the loop and the web responder and just skipped the ring_states array I had been trying to share. The web responder turns my outputs on in response to the urls and the loop turns them off in response to the reset input.
Since I am on a train and didn’t have a jumper handy, I found I was able to make a sort of cheat toggle that worked to send a binary message from the web responder to the loop using the hardware. I changed the pullup status of the reset_pin loop was watching to emulate a button push and got loop to reset the outputs in response to some debugging urls.
Seems to work OK.
Thanks again for your help, suggestion, and for your work on BoneScript!
This is what I wound up with: (I’ll be changing the LED outputs to normal outputs that will connect to a relay driver)
require(‘bonescript’);
fs = require(‘fs’);
child_process = require(‘child_process’);
http = require(‘http’);
url = require(‘url’);
path = require(‘path’);
events = require(‘events’);
server = false;
reset_pin = bone.P8_4;
or_pin = bone.P8_5;
pin_count = 4;
indicator_pins = new Array(bone.USR1, bone.USR2, bone.USR3, bone.P8_3);
ring_uris = new Array(’/1’, ‘/2’, ‘/3’, ‘/4’);
setup = function() {
pinMode(reset_pin, INPUT);
pinMode(or_pin, OUTPUT);
var idx;
for(idx = 0; idx < pin_count; idx++)
pinMode(indicator_pins[idx], OUTPUT);
server = http.createServer(
function(req, res) {
var uri = url.parse(req.url).pathname;
console.log("Got URI: " + uri);
var idx;
for (idx = 0; idx < pin_count; idx++)
if (uri == ring_uris[idx])
digitalWrite(indicator_pins[idx], HIGH);
digitalWrite(or_pin, HIGH);
console.log("matched uri at index " + idx);
break;
//up and down are for testing only. remove before deployment
if (uri == ‘/up’)
pinMode(reset_pin, INPUT_PULLUP);
if (uri == ‘/down’)
res.writeHead(200, {“Content-Type”: “text/html”});
res.end();
server.listen(5400);
loop = function() {
var idx;
if (digitalRead(reset_pin))
digitalWrite(indicator_pins[idx], LOW);
digitalWrite(or_pin, LOW);
