Wanted to cross post this over here on the forums. I have my BBB using bonescript to fire LED’s on various pins on P9.
I am finding that some pins will not fire an LED like others will. So I put together a simple script to isolate the issue. I was hoping that someone out there could try to blink an LED on pin 17 using bonescript for me.
I am trying to find out if:
there is a bug in the bonescript lib
my BBB is defective
P9_17 is a special pin that will never be able to blink.
I am working on building a shield and need to find some available pins up in that P9 header, although I could likely hunt and find some more pins that are working, I would prefer to understand why it is not blinking.
Thanks so much Gerald. We are trying to get our new cape off to production. But with several of the pins we need not working we have held off while we make sure we will have access to all the pins we need.
I am wondering if I have something wrong with my bbb. I am just not seeing an output voltage on several of those pins in the P9_11-30 range. But wanted to have someone else verify to see if we could narrow it down to hardware or a problem with the bonescript lib.
I ran mine and my 9_17 is set in mux 2, which is i2c1_scl, as shown below. If you want to use it as a GPIO, you have to set the mux to 7 so that the pin will be a GPIO. Have you tried that?
Thanks for the help Juan. I am aware of the various mux modes. Bonescript uses mode 7 by default. If you look at the code at https://github.com/jadonk/bonescript/issues/44 you can see that I actually set it to 7 there as well. There is also a post there of what I get when I do the getPinMode() , I see that P9_17 is in mux 2.
Could the bug be that bonescript is not actually setting the mux mode properly? Do we need to rope in JasonK ?
Jason has been working on getting all the functions to work on bonescript. My recommendation to you would be to set a device tree overlay to mux the pin. This link is a good reference for that. (http://hipstercircuits.com/category/device-tree/)
Thanks for submitting the issue though! Hopefully it will get fixed soon.
