boot BeagleBoard from NFS server
Hello
I try to boot my BeagleBoard xM Rev.C from an NFS server which is running on an Ubuntu 10.04 host.
The NFS server seems to work fine because i am able to mount it on an Angstrom Linux which runs on my BeagleBoard (SD-Card).
To boot the BeagleBoard from NFS i use the Angstrom-console-image-eglibc-ipk-v2012.05-beagleboard.rootfs.tar.bz2 rootfs.
My uEnv.txt file looks like:
serverip=192.168.0.2
ipaddr=192.168.0.9
netmask=255.255.255.0
gatewayip=192.168.0.1
hostname=beagleboard
nfsdevice=usb0:off
usbethaddr=6E:58:95:1B:82:65
optargs=mem=99M@0x80000000 mem=384M@0x88000000
nfsargs=setenv bootargs console=tty02,115200n8 mpurate=1000 ${optargs} ip=dhcp nfsroot=192.168.0.2:/home/kli/rootfs root=/dev/nfs rw rootwait
uenvcmd=echo Initializing net …; dcache off; usb start; echo Loading kernel …; nfs ${loadaddr} 192.168.0.2:/home/kli/rootfs/boot/uImage ; echo Booting from nfs …; run nfsargs; bootm ${loadaddr}
and when i boot the system i get the log :
U-Boot SPL 2011.12-dirty (May 26 2012 - 14:13:36)
Texas Instruments Revision detection unimplemented
OMAP SD/MMC: 0
timed out in wait_for_bb: I2C_STAT=1000
reading u-boot.img
reading u-boot.img
U-Boot 2011.12-dirty (Jun 13 2012 - 09:13:11)
OMAP3630/3730-GP ES1.2, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
OMAP3 Beagl
e board + LPDDR/NAND
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #578600029ff80000015f26ad0f00c028
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 2
\0x08\0x08\0x08 1
\0x08\0x08\0x08 0
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
557 bytes read
Running uenvcmd …
Initializing net …
Data (writethrough) Cache is OFF
(Re)start USB…
USB: Register 1313 NbrPorts 3
USB EHCI 1.00
scanning bus for devices…
3 USB Device(s) found
scanning bus for storage devices… 0 Storage Device(s) found
scanning bus for ethernet devices… 1 Ethernet Device(s) found
Loading kerne
l …
Waiting for Ethernet connection…
done.
Using sms0 device
File transfer via NFS from server 192.168.0.2; our IP address is 192.168.0.9
Fil
ename ‘/home/kli/rootfs/boot/uImage’.
Load address: 0x80200000
Loading: *\0x08#################################################################
\0x09 ###################################################
I found out that the kernel command line is not using the correct root variable from the uEnv.txt file.
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=99M@0x80000000
mem=384M@0x88000000
mpurate=auto buddy=none buddy2=none camera=none vram=12M
omapfb.mode=dvi:640x480MR-16@60 omapdss.def_disp=dviroot=ubi0:rootfs
ubi.mtd=4 rootfstype=ubifs
I tried to change the uboot variables with
$ setenv root /dev/nfs rw
$ printenv root
       root=/dev/nfs rw
$ saveenv
       Saving Environment to NAND...
       Erasing Nand...
       Attempt to erase non page aligned data
but without success. After i reboot the BeagleBoard xM the variable is
again set to root=ubi0:rootfs.
BeagleBoard-xM does not have any NAND on it. You need to edit the
uEnv.txt file on the FAT partition.
Thanks for the answer
I found out that i had a problem with the uboot which had overwritten the kernel command line which i passed with the uEnv.txt file.
(actually i use the uboot, MLO and Angstrom-systemd-image-eglibc-ipk-v2012.05-beagleboard.rootfs.tar.bz2 from http://downloads.angstrom-distribution.org/demo/beagleboard/)
Now i get the correct kernel command line in my boot-log:
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mpurate=1000 mem=99M@0x80000000 mem=384M@0x88000000 ip=192.168.0.9:192.168.0.2:192.168.0.1:255.255.255.0:beagleboard:usb0:off nfsroot=192.168.0.2:/home/kli/rootfs,vers=3 root=/dev/nfs rw rootdelay=15
but the NFS boot is still failing with the error:
[ 16.343048] Waiting 15sec before mounting root device…
[ 126.390014] VFS: Unable to mount root fs via NFS, trying floppy.
[ 126.396820] VFS: Cannot open r**oot device “nfs” or unknown-block(2,0)
[ 126.403533] Please append a correct “root=” boot option; here are the available partitions:
[ 126.412353] b300 1931264 mmcblk0 driver: mmcblk
[ 126.417999] b301 72261 mmcblk0p1 00000000-0000-0000-0000-000000000mmcblk0p1
[ 126.426452] b302 1855507 mmcblk0p2 00000000-0000-0000-0000-000000000mmcblk0p2
[ 126.434997] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
[ 126.443695] [] (unwind_backtrace+0x0/0xe0) from [] (panic+0x50/0x180)
[ 126.452331] [] (panic+0x50/0x180) from [] (mount_block_root+0x1bc/0x1fc)
[ 126.461181] [] (mount_block_root+0x1bc/0x1fc) from [] (mount_root+0xd0/0xec)
[ 126.470428] [] (mount_root+0xd0/0xec) from [] (prepare_namespace+0x15c/0x1bc)
[ 126.479766] [] (prepare_namespace+0x15c/0x1bc) from [] (kernel_init+0xfc/0x134)
[ 126.489288] [] (kernel_init+0xfc/0x134) from [] (kernel_thread_exit+0x0/0x8)
I am able to mount the NFS server on my beagleboard with → busybox mount -t nfs 192.168.0.2:/home/kli/rootfs /export
So i think the NFS server should work just fine.
I was searching for a solution all over the net but without success and it would be really nice to get some help.
The complete logfile is added as logfile.txt
Wendelin
logfile.txt (16.4 KB)
I followed the instructions from → http://veter-project.blogspot.co.at/2012/03/comfortable-kernel-workflow-on.html, but i did not use the same kernel (Xenomai) so i had to recompile my kernel with the LAN driver statically
(make menuconfig → Device driversNetwork device supportUSB Network AdaptersSMSC LAN95XX USB Ethernet devices and Device drivers → USB support → EHCI HCD (USB 2.0) )
moreover i had to change the uEnv.txt file
ipaddr=192.168.0.9
optargs=mem=80M@0x80000000 mem=384M@0x88000000 xeno_hal.cpufreq=800000000
mpurate=800
root=/dev/nfs rw
rootpath=/home/maker/rootfs
nfsdevice=usb0:off
nfsrootargs=vers=3
nfsargs=setenv bootargs console=${console} mpurate=${mpurate} ${optargs} ip=dhcp nfsroot=${serverip}:${rootpath},${nfsrootargs} root=${root}
uenvcmd=echo Initializing net ...; dcache off; usb start; echo Loading kernel ...; nfs ${loadaddr} ${serverip}:${rootpath}/boot/uImage ; echo Booting from nfs ...; run nfsargs; bootm ${loadaddr}
(-> ip=dhcp)
to get the BeagleBoard to boot from the NFS server.
Thanks for the help
Hi kli, did you remove the drivers that you mention or did you enable them:
EHCI HCD (USB 2.0)
I am having problems, my network is dhcp, and when trying to load the kernel it hangs at:
U-Boot SPL 2011.12-dirty (Mar 04 2013 - 09:50:47)
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.12-00010-ga3eb89c (Jan 29 2012 - 14:53:43)
OMAP36XX/37XX-GP ES1.2, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
Die ID #467800029ff80000016849a90601f007
No ethernet found.
reading uEnv.txt
726 bytes read
Running uenvcmd …
Initializing net …
(Re)start USB…
USB EHCI 1.00
scanning bus for devices… 5 USB Device(s) found
Loading kernel …
Waiting for Ethernet connection… done.
Using sms0 device
File transfer via NFS from server 152.78.67.171; our IP address is 152.78.70.95
Filename ‘/home/maker/rootfs/boot/uImage’.
Loading: T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
Even when using dhcp, is it a problem if the BBxM and host are in different subnets?
Thanks for any help,
Luis
Hy
