Hi everybody and thanks in advance…
i’ve a strange issue, because my beagle works fine with Angstrom (with original kernel 2.6.32 and 3.1 customized ) but i can’t see in my terminal minicom the kernel massages and the prompt login in the end of boot.
Instead the external monitor works fine!!!
I need to control the Angstrom from minicom.
My bootargs is:
OMAP3 beagleboard.org # printenv bootargs
bootargs=console=ttyO2,115200n8 root=/dev/mmcblk0p2 rw rootwait
the consol’s messages are blocked here:
OMAP3 beagleboard.org # boot
gpio: pin 173 (gpio 173) value is 1
gpio: pin 7 (gpio 7) value is 0
SD/MMC found on device 0
reading uEnv.txt
** Unable to read “uEnv.txt” from mmc 0:1 **
Loading file “/boot/uImage” from mmc device 0:2
3203088 bytes read
Booting from mmc …
Booting kernel from Legacy Image at 80200000 …
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3203024 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux…
Sometime it works, but i don’t know why!!
thanks for any help.
Nicola
