I’d like to report something odd I have experienced with the ubuntu-14.04.1-console-armhf-2014-10-29.tar.xz distribution installed on an 8 Gb SD card. It all boots fine and a connection can be made to the BBB via the USB keyboard/HDMI monitor and also via ssh from a remote PC.
However, connecting up the USB cable from the BBB to a PC running Ubuntu 14.04 LTS destroys the ability of the BBB to boot from that SD card. Any existing ssh connections into the BBB return the phrase “bus failure” upon the next key press. Removing the USB cable and attempting to reboot results in a BBB with a failed boot and all four LEDs fully on. The only option is to reinstall onto the SD card. The BBB as USB does appear in the remote PC’s launcher bar but the contents of the BBB cannot be viewed in the File Manager.
Also, I doubt this is related, but an SD card formatted up with the ubuntu-14.04.1-console-armhf-2014-10-29.tar.xz image requires the button to be pressed on each boot - otherwise it boots from EMMC. I am not sure what is controlling this, but other SD cards I have formatted up only seem to require the button press on the first boot and the BBB remembers it thereafter.
These issues may be known about already - sorry if that is the case.
I'd like to report something odd I have experienced with the
existing ssh connections into the BBB return the phrase "bus failure" upon
to reinstall onto the SD card. The BBB as USB does appear in the remote PC's
Manager.
odd, haven't seen that.
thereafter.
the problem remains. I tested this several times and I did see (once) the BBB appear as a USB drive on the remote PC. In that instance the BBB did reboot successfully. However after rebooting and again plugging in the USB cable, the error appeared, the BBB would not mount as a USB drive and the SD card was rendered unbootable.
I have found an error message reported by the remote Linux PC. This appears to be output by the process which is trying to mount up the BBB as a drive over USB:
Error mounting /dev/sdb at /media/dtree/rootfs: Command-line `mount -t “ext4” -o “uhelper=udisks2,nodev,nosuid” “/dev/sdb” “/media/dtree/rootfs”’ exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/sdb,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
BTW, i'm yanking the "usb media" in situations where there is only
"one" partition.. (it works in some situations but i've been getting
lots of other issues by email.)
