Boot problem on BBB Rev C Debian 7.4
So my Rev C has arrived. When it boots I see one error:
spl_load_image_fat_os: error reading image args, err - -1
and one warning:
I’ve searched for the error, but can’t find anything helpful. I’m a noob, so would someone kindly point me in the right direction.
Thanks in advance,
Dwight
root@beaglebone:~# cat /etc/debian_version
7.4
root@beaglebone:~# reboot -f
[ 931.817654] (NULL device *): gadget not registered.
[ 931.823689] Restarting system.
U-Boot SPL 2014.04-00015-gb4422bd (Apr 22 2014 - 13:24:29)
reading args
reading u-boot.img
reading u-boot.img
U-Boot 2014.04-00015-gb4422bd (Apr 22 2014 - 13:24:29)
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
cpsw, usb_ether
mmc0 is current device
SD/MMC found on device 0
** File not found uEnv.txt **
Checking if uenvcmd is set …
uenvcmd was not defined in uEnv.txt …
SD/MMC found on device 1
reading uEnv.txt
1430 bytes read in 5 ms (279.3 KiB/s)
Running uenvcmd …
reading zImage
3717760 bytes read in 205 ms (17.3 MiB/s)
reading initrd.img
2870013 bytes read in 161 ms (17 MiB/s)
reading /dtbs/am335x-boneblack.dtb
25080 bytes read in 9 ms (2.7 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x38ba80 ]
Using Device Tree in place at 88000000, end 880091f7
Starting kernel …
[ 0.381227] omap2_mbox_probe: platform not supported
[ 0.548027] tps65217-bl tps65217-bl: no platform data provided
[ 0.612208] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.649316] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.686423] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.723532] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.739689] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.749299] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.756053] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.772610] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 0.835142] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.846833] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.854130] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
Loading, please wait…
Scanning for Btrfs filesystems
systemd-fsck[210]: rootfs: clean, 77151/230144 files, 378491/919296 blocks
Press enter for maintenance(or type Control-D to continue): enter default mode.
[ 305.244488] libphy: PHY 4a101000.mdio:01 not found
[ 305.249633] net eth0: phy 4a101000.mdio:01 not found on slav
It's nothing to worry about.
Please provide the solution for this
