Yes, I believe that is what we used. I would have to check that to make sure. The ai64 is around 10 seconds on an arago image.
If you build the demo image it has the sgx gpu active and it will run weston compositor on bbb. The bare image is MACHINE=“BeagleBone”, core-image-minimal.
FYI, you will need at least 400 Gb of NVMe, and 32 Gb ram, set your swap to 60Gb and swap on a secondary NVMe, not your boot drive.
