Last time I bothered to look at the uboot source code I am fairly sure uSD was the first in the roundrobin.
Regardless, I have a board booted now that has Angstrom on the eMMC still, and uboot MLO, plus the kernel on uSD, with the rootfs on an NFS server. Freshly built a week or two ago.
$ uname -a
Linux arm 3.8.13-bone47 #1 SMP Mon Apr 14 04:38:52 MST 2014 armv7l GNU/Linux
$ df -h /
Filesystem Size Used Avail Use% Mounted on
192.168.0.1:/home/william/rootfs 49G 4.9G 41G 11% /
$ nano /boot/uboot/uEnv.txt
kernel_file=zImage
initrd_file=uInitrd
serverip=192.168.0.1
ipaddr=192.168.0.2
static_ip=192.168.0.2:192.168.0.1:192.168.0.1:255.255.255.0:arm
rootpath=/home/william/rootfs,rsize=16384,wsize=16384
console=ttyO0,115200n8
optargs=ipv6.disable=1
#mmcroot=/dev/mmcblk0p2 ro
#mmcrootfstype=ext4 rootwait fixrtc
loadkernel=load mmc ${mmcdev}:${mmcpart} 0x80200000 ${kernel_file}
loadinitrd=load mmc ${mmcdev}:${mmcpart} 0x81000000 ${initrd_file}; setenv initrd_size ${filesize}
loadfdt=load mmc ${mmcdev}:${mmcpart} 0x815f0000 /dtbs/${fdtfile}
#mmcargs=setenv bootargs console=${console} root=${mmcroot} rootfstype=${mmcrootfstype}
netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},vers=3 rw iip=${static_ip}
#just zImage
boot_ftd=run loadkernel; run loadfdt
uenvcmd=run boot_ftd; run netargs; bootz 0x80200000 - 0x815f0000
#zImage + uInitrd: where uInitrd has to be generated on the running system.
#boot_ftd=run loadkernel; run loadinitrd; run loadfdt
#uenvcmd=run boot_ftd; run mmcargs; bootz 0x80200000 0x81000000:${initrd_size} 0x815f0000
NOTE: The above uEnv.txt file is /was provided by none other than Robert C Nelson answering the OP’s post here. Slightly modified by myself of course. THis causes the BBB to “boot” from the uSD card, then mount the rootfs over our network provided by a Debian NFS server. Allso, YES optargs=ipv6.disable=1 does work . .
Anyway, yes you’re only spinning your wheels until you get a FTDI cable / module hooked up. OR If you have a MSP430 Launchpad v1.5, and are in a hurry, I could link you to a post I made about using the Launchpad instead. However this may not work depending on how far into the boot process you’re getting. As uboot is hardcoded to use 115200 bps when it first starts up. The launchpad is only capable of 9600 bps.
