Purchased a new BB-xM.
As per the instructions,fomatted the micor SD card.
Now my SD card contains dos files(COMMAND.com,IO.SYS,MSDOS.SYS,EBOOTSD.nb0,NK.bin,MLO files.
I’ve plugged in using 5v powersupply,usbcable ,and SD provided in the given slot.
Using Teraterm as emulator and after the setup done…
It displays the following message…
Windoÿs CE SD X-Loader 37XX Built Jõn 11 2011 at 00:03:17 Version 1.02.00.01 oðen ebootnd.nb0 file Init HW: controller RST SDHC: command resðonse timeout CTO! SD boot failed to oðen ebootnd file oðen ebootsd.nb0 file
wat cud be the reason…
Appreciate your help and suggestions…
Many thanks
Hello all,
what instructions are that?
I've plugged in using 5v powersupply,usbcable ,and SD provided in the given slot.
Using Teraterm as emulator and after the setup done...
It displays the following message...
*Windo�s CE SD X-Loader 37XX
Built J�n 11 2011 at 00:03:17
Version 1.02.00.01
o�en ebootnd.nb0 file
SDHC: command res�onse timeout CTO!
SD boot failed to o�en ebootnd file
o�en ebootsd.nb0 file*
wat cud be the reason...
If you could send us the source code, we could have
a look...
Appreciate your help and suggestions...
Many thanks
since you are trying to boot windows CE which is a
closed source commercial project that few people
here have worked with, I would suggest you
ask the provider of windows CE for help.
