while i try to boot the linux kernel on the beagleboard xm i am
getting the below error
Kernel panic - not syncing: Fatal exception in interrupt
pls suggest the solution if anybody has solved it??
Did you use the USB OTG to power the board? If so, try to use a 5V DC supply.
hi laputa
thnks for the suggestion, it worked when i switched over to dc
supply
hey can u guide to set up the NFS to mount the rootfs??
