booting error with BBB [Error: unrecognized/unsupported machine ID (r1 = 0x00000e05).]
hello,
i’m creating a kernel image for beaglebone black,while processing i faced the following issue.
i referred the following links to create uImage-BBB
http://elinux.org/Building_BBB_Kernel#Downloading_and_building_the_Linux_Kernel
http://wiki.beyondlogic.org/index.php/BeagleBoneBlack_Building_Kernel
while use this link i stuck with creating uImage-dtb.am335x-boneblack image
make ARCH=arm CROSS_COMPILE=arm-linux-gnu- uImage-dtb.am335x-boneblack
after a series of discussing with google groups i found 1 more useful link to create uImage for beagle bone black
https://groups.google.com/forum/#!category-topic/beagleboard/beaglebone-black/mShGQ3dfI08
from the google-group guidelines i was able to create the uImage-BBB successfully but not able to run the kernel with my board
here the procedure i followed to create a kernel image and error log report for your understanding
procedures i used :
Looks like DT file loading before booting is missing.
For kernels >3.2 and BBB you should pre-load dtb with u-boot to boot succesfully (or append dtb file to kernel image, but have to CONFIG_ARM_APPENDED_DTB kernel compile option enabled).
There is also a possibility that dtb is loaded correctly, but the kernel is too big and when decompresses overwrites dtb - it easy to check if the situation happened in your case with nm tool- no symbol should be loaded above c0f80000 for default u-boot config,
T.
buddy…
thanks for your useful information…
now i can able to boot the kernel from scratch !!!..
but as usual kernel panic error occurred …this might be a problem with nfs configuration!!!
[ 4.688893] IP-Config: Complete:
[ 4.692338] device=eth0, hwaddr=90:59:af:5b:d4:88, ipaddr=192.168.1.61, mask=255.255.255.0, gw=192.168.1.100
[ 4.703098] host=192.168.1.61, domain=, nis-domain=(none)
[ 4.709215] bootserver=192.168.1.69, rootserver=192.168.1.69, rootpath=
[ 4.716420] ALSA device list:
[ 4.719726] #0: TI BeagleBone Black
[ 4.860556] VFS: Mounted root (nfs filesystem) on device 0:12.
[ 4.867169] devtmpfs: mounted
[ 4.870723] Freeing init memory: 292K
[ 4.926371] Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[ 4.939425] [] (unwind_backtrace+0x0/0xe0) from [] (panic+0x84/0x1e0)
[ 4.947988] [] (panic+0x84/0x1e0) from [] (kernel_init+0xb8/0xe4)
[ 4.956185] [] (kernel_init+0xb8/0xe4) from [] (ret_from_fork+0x14/0x3c)
[ 4.965008] drm_kms_helper: panic occurred, switching back to text console
buddy…
NFS doesn’t like initrd, so you must build your kernel without initrd and replace the initrd reference with a - (dash) in uEnv.txt so uenvcmd will look like this
uenvcmd=run boot_ftd; run device_args; bootz 0x80200000 - 0x815f0000
John
