How do i configure BB RevC to boot from NAND first? Thanks,
http://elinux.org/BeagleBoard#User_button
Best regards
Dirk
Dirk,
Right now when i turn on the BB w/o SD inserted, nothing happened. I used to be able to boot from nand w/o having to P/H release the User button. Previously i was following the steps in elinux or codegoogle to build the SD and that when the BB RevC doesn’t behave the way it was originally configure. Is there something i could change in the env to restore the original config? Thanks
rene’
Sounds like you may have corrupted the NAND. Go to http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation for instructions on how to restore the NAND.
