again, just some pedantry and making sure i understand the search
order here, if i create a new SD card for my BBB with nothing but raw
MLO and u-boot.img images dd'ed to card (no partitions), then boot,
what i see is:
switch to partitions #0, OK
mmc0 is current device
** No partition table - mmc 0 **
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
technically, that makes sense, mmc0 above represents the SD card and
u-boot would seem to be looking for uEnv.txt first in a partition on
the SD card but since i have no partition at all, it will fail. but
(and this is admittedly more a u-boot question), is there any reason
that u-boot can't just notice there's no partition and not spend all
that time trying over and over looking for different files, since all
of them will fail? it's not wrong, it just seems inefficient.
also, to follow up on my earlier question, it looks like, if i want
to add nothing but uEnv.txt to the mix, i can create that ext4
partition on the card, then populate it with *nothing* but
/boot/uEnv.txt, is that correct?
rday
what i see is:
Last i checked, there wasn't a check for partition existence in u-boot.
For /uEnv.txt/boot.scr/boot/boot.scr/boot/uEnv.txt It's just use the
"file existence" check before trying to load it.
if test -e mmc ${bootpart} /uEnv.txt; then
All you need in t /boot/uEnv.txt is a variable:
uname_r=
(kernel: uname -r syntax)
Unless your also using the eMMC, then it's really best to have:
uuid=
http://elinux.org/Beagleboard:U-boot_partitioning_layout_2.0
