Hello
I am trying to boot BBB from uSD card but uboot is not working as expected , I am getting this error
Partition 1 Not Valid on device 0*
SPL:fat register err --1
I am using 8GB uSD card .
I tried to do little debugging actually MLO fails while registering FAT partition.
->fat_register_device
If you could help. I am using latest rev of BBB
Hi Robert ,
As you mentioned i tried but still same problem .
board=am335x
board_name=A335BNLT
board_rev=0A6A
Disk /dev/mmcblk0: 1983 MB, 1983905792 bytes
4 heads, 16 sectors/track, 60544 cylinders, total 3874816 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 2048 100351 49152 e W95 FAT16 (LBA)
/dev/mmcblk0p2 100352 3874815 1887232 83 Linux
is it correct partition???
U-Boot SPL 2014.04-dirty (Jun 05 2014 - 20:31:45)
** Partition 1 not valid on device 0 **
spl_register_fat_device: fat register err - -1
ERROR ### Please RESET the board
boot from eMMC then on u-boot prompt i tried to run few commands
U-Boot# fatinfo mmc 0:1
** No partition table - mmc 0 **
U-Boot# mmcinfo
Device: OMAP SD/MMC
Manufacturer ID: 84
OEM: 5446
Name: MSTran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: No
Capacity: 1.8 GiB
Bus Width: 4-bit
What can be the issue Hardware ??
Abhishek
yousif
4
Hi Abhishek,
did you figure out the problem??
