Booting Issue beaglebone black
My BBB doesn’t boot, I tried flashing it with factory Angstrom image available at beagleboard.org website. The 4 LEDs light up and the process is completed. But doesn’t boot even after that. To see what is happening I connected my Serial to USB converter to the BBB and using Putty I saw the U-Boot message which appears like the following:
U-Boot SPL 2013.04-dirty (Jul 10 2013 - 14:02:53)
timed out in wait_for_pin: I2C_STAT=0
Could not probe the EEPROM; something fundamentally wrong on the I2C bus.
Could not get board ID.
Unknown board, assuming Beaglebone LT/Black.musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jul 10 2013 - 14:02:53)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
Card did not respond to voltage select!
mmc0(part 0) is current device
No micro SD card found, setting mmcdev to 1
SD/MMC found on device 1
reading uEnv.txt
26 bytes read in 3 ms (7.8 KiB/s)
4385024 bytes read in 768 ms (5.4 MiB/s)
24808 bytes read in 54 ms (448.2 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4384960 Bytes = 4.2 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f890e7
Starting kernel …
[ 1.148261] omap_i2c 44e0b000.i2c: controller timed out
[ 1.148304] tps65217 0-0024: Failed to read INT reg
[ 1.148322] tps65217 0-0024: Failed to probe pwr_but
[ 2.148252] omap_i2c 44e0b000.i2c: controller timed out
[ 3.152151] omap_i2c 44e0b000.i2c: controller timed out
[ 3.182788] omap2_mbox_probe: platform not supported
[ 4.246560] omap_i2c 44e0b000.i2c: controller timed out
[ 5.254176] omap_i2c 44e0b000.i2c: controller timed out
[ 6.767826] omap_i2c 44e0b000.i2c: controller timed out
[ 7.779563] omap_i2c 44e0b000.i2c: controller timed out
[ 9.293213] omap_i2c 44e0b000.i2c: controller timed out
[ 10.305060] omap_i2c 44e0b000.i2c: controller timed out
[ 11.818596] omap_i2c 44e0b000.i2c: controller timed out
[ 12.830340] omap_i2c 44e0b000.i2c: controller timed out
Similarly when I try to boot the board using Ubuntu on SD Card I see the following message:
▒m▒▒▒▒▒▒▒rpqsnqpmpprtym▒qu▒u▒▒▒h▒▒▒qw@rpqsmqvzsuzqqi
i2c_probe: pads on bus 0 probably not configured (status=0x10)
Unknown board, cannot configure pinmux.### ERROR ### Please RESET the board ###
After the flashing did you remove the power from the board as instructed?
http://www.elinux.org/Beagleboard:Updating_The_Software
Yes I did Gerald. I removed the power supply then only I removed the sd card and gave power to it again. I have already flashed my eMMC once as soon as a bought it last week as I ran into boot problem as I deleted some file during date time update. At that time it worked, so I know the flashing process. I was running ubuntu precise from my sd card, and I was trying to use the leftover space available in the sd card by following the guide in the following web link: http://elinux.org/Beagleboard:Expanding_File_System_Partition_On_A_microSD, only after doing this, I ran into the booting issue that I am not able to fix. Thanks in advance for your reply.
My BBB doesn't boot, I tried flashing it with factory Angstrom image
is completed. But doesn't boot even after that. To see what is happening I
Do you have any boards attached? This is an odd response.
SoftConn)
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 512 MiB
0 MiB
SoftConn)
SoftConn)
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
reading uEnv.txt
Importing environment from mmc ...
Booting from mmc ...
## Booting kernel from Legacy Image at 80007fc0 ...
   Verifying Checksum ... OK
## Flattened Device Tree blob at 80f80000
   XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
It again looks like something is hanging on your I2C bus besides the
EEPROM. It is conceivable the board has been damaged, but I'm more
suspicious of something hanging on the lines.
following message:
▒m▒▒▒▒`▒▒▒`rpqsnqpmpprtym▒qu▒u▒▒▒`h▒▒▒`qw@rpqs`m`qvzsuzqqi
board ###
Yup, all of this points to problems reading the on-board EEPROM more than
it just being corrupted. It is possible to reprogram it, but it just looks
like you can't even access it. What else has been done to this board?
__
Can any of you Guys figure out what is the problem? and how to fix it?
Thanks in Advance for your solution.
You'd need to probe the I2C pins to see if they are toggling or if
something has them strapped. There are many dependencies that would be a
pain to remove if you weren't able to fix the ability to read the EEPROM.
Thanks for the quick support Jason. Since, I didn’t get any reply from any of your support team for last few days, I posted a new post at http://beagleboard.org/Community/Forums?place=topic%2Fbeagleboard%2FyLAbudOgAIU%2Fdiscussion
And Robert has entered the discussion. Kindly take a look at it to know what I tried after this.
And which support team is that?
I don’t know Gerald. There must be a team of members who will be working for support. Do you have any idea on what the issue with my board is, any idea on how to fix it.
All support is community based. There is a support email address and that comes to me. I see one email per month at that address.
Sounds like the board is damaged to me or the EEPROM has been overwritten… My suggestion is that you request an RMA so that we can take a look at the board to see what is wrong…
http://www.elinux.org/Beagleboard:BeagleBoneBlack#RMA_Support
Ok, now I understand about the support. Is there no other way or option that I can try to fix it myself. I will take a look into RMA. Thanks for the reply.
Well, considering the fact I have no idea what the issue is, that would be rather hard to do.
Ok Gerald. Thanks for the support.
