Bricked board
While playing with NAND I bricked my board :frowning:
In uboot, I did something like
loadb 80200000
<send xloader>
nand unlock
nand erase 0 80000
nand write 80200000 0 80000
but something went wrong. Seems that now bootrom detects something in NAND flash and then crashes.
Result is that with User button _not_ pressed I don't get anything any more, no ..40T.. nothing.
Okay, then _pressing_ the user button should bring me back to U-Boot from SDCard. But this results in
-- cut --
...40T......
Texas Instruments X-Loader 1.41
Starting on with MMC
Reading boot sector
717948 Bytes Read from MMC
Starting OS Bootloader from MMC...
U-Boot 1.1.4 (Apr 2 2008 - 13:42:13)
OMAP3430-GP rev 2, CPU-OPP2 L3-133MHz
TI 3430Beagle 2.0 Version + mDDR (Boot ONND)
DRAM: 128 MB
Flash: 0 kB
NAND:NAND device: Manufacturer ID: 0x2c, Chip ID: 0x01 (-ge AND 128MiB 3,3V 8-bit)
NAND bus width 16 instead 8 bit
0 MiB
<nothing any more>
-- cut --
Any idea? I think I need at least a working Uboot prompt to be able to erase trash in NAND flash?
Above is TI's uboot from code.google.com, but same happens with Steve's git uboot.
Dirk
My recollection, and I hope Khasim will flame me if I'm wrong, is that
there was a bug in MLO that could cause boot failures from MMC/SD when
there were some wrong contents in the NAND flash. I believe there is
a version that fixes this. I used to have this problem quite
frequently when first trying out flash.
The shorter-term work-around is to boot via the serial port. Once you
have loaded a valid u-boot, you can erase the flash and get back to
normal operation.
