I wrote to Nand and all my interfaces went dead. I only get the power light now. Is there a way to flash it back to factory settings?
PLEASE HELP!
PLEASE HELP!
I ran into the same issue. I tried everything on the in the recovery website without much luck. Let me know if you find a solution. Thanks.
NO GO
Make sure that you use a freshly formatted SD card and you make the MLO the first file written to the card.
If you can’t repair the board by following the steps to the letter, then the only thing I can suggest is that you send the board in for repair.
