Broken I2C Rev A6?
According to U-boot, there are serious issues on my new A6 BBB:
U-Boot SPL 2013.04-dirty (Jun 19 2013 - 09:57:14)
timed out in wait_for_pin: I2C_STAT=0
Could not probe the EEPROM; something fundamentally wrong on the I2C bus.
Could not get board ID.
Unknown board, assuming Beaglebone LT/Black.musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
U-Boot#
The error “Could not probe the EEPROM” and “No NAND device found” show up.
Mine too Sri. Did you fix this issue or findout whats wrong.
