I was reading carefully the following example taken from here:
file: button.c
define _GNU_SOURCE 1
#include “stdio.h”
#include <termios.h>
#include <unistd.h>
#include <errno.h>
#include <sys/types.h>
#include <sys/time.h>
#include “…/c_wrapper/pruio.h”
#include “…/c_wrapper/pruio_pins.h”
#define PIN P8_07
int
isleep(unsigned int mseconds)
fd_set set;
struct timeval timeout;
/* Initialize the file descriptor set. */
FD_ZERO(&set);
FD_SET(STDIN_FILENO, &set);
/* Initialize the timeout data structure. */
timeout.tv_sec = 0;
timeout.tv_usec = mseconds * 1000;
return TEMP_FAILURE_RETRY(select(FD_SETSIZE,
&set, NULL, NULL,
&timeout));
int main(int argc, char **argv)
pruIo *io = pruio_new(PRUIO_DEF_ACTIVE, 0x98, 0, 1); // <= LOOK HERE
do {
if (io->Errr) {
printf(“initialisation failed (%s)\n”, io->Errr); break;}
if (pruio_config(io, 1, 0x1FE, 0, 4)) {
printf(“config failed (%s)\n”, io->Errr); break;}
struct termios oldt, newt; // make terminal non-blocking
tcgetattr( STDIN_FILENO, &oldt );
newt = oldt;
newt.c_lflag &= ~( ICANON | ECHO );
newt.c_cc[VMIN] = 0;
newt.c_cc[VTIME] = 0;
tcsetattr(STDIN_FILENO, TCSANOW, &newt);
while(!isleep(1)) { // run loop until keystroke
printf("\r%1X", pruio_gpio_Value(io, PIN));
fflush(STDIN_FILENO);
tcsetattr(STDIN_FILENO, TCSANOW, &oldt); // reset terminal
printf("\n");
} while (0);
pruio_destroy(io); /* destroy driver structure */
return 0;
In the following line of code you can read that the value 0x98 is the second argument passed to the function.
BUT In the documentation I found that:
pruIo* pruio_new ( uint16 Act, uint8 Av, uint32 OpD, uint8 SaD )
Wrapper function for the constructor PruIo::PruIo().
- Parameters
Act mask for active subsystems and PRU number Av avaraging for default steps (0 to 16, defaults to 0) OpD open delay for default steps (0 to 0x3FFFF, defaults to 0x98) SaD sample delay for default steps (0 to 255, defaults to 0)
Is there a problem in the documentation or somewhere else??
