i have done the bitbake console-image successfully,
while building the bitbake x11-image and bitbake dvb-image, bitbake
console-mpiv6 i am getting the following error
log file(log.do_compile) is attached to this.
this error is generated during the following command
bitbake openmoko-image command on OE ubuntu machine.
> > I am trying to build angstorm on ubuntu machine for beagle board.
> > I am following the instructions given inhttp://www.openembedded.org,
> As I said before, that's not the actual error. bitbake gave you a
> error log as well.
> Hi,
please go through that attached log file...
/home/kishore/tmp/cross/armv7a/lib/gcc/arm-angstrom-linux-gnueabi/
4.3.1/../../../../arm-angstrom-linux-gnueabi/bin/ld:.libs/
libgdk_pixbuf-2.0.ver:2: ignoring invalid character `\001' in script
libgdk_pixbuf-2.0.ver:2: syntax error in VERSION script
that does mean you have (or have had) /bin/sh pointing to dash during
the build.
