Building drivers without source on BBB
HI,
I am using this Makefile to build the kernel driver on the BBB itself(already apt-get installed build-essenatials on it).
obj-m += myDrvr.o
all:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
But I am getting this error :
make -C /lib/modules/4.1.22-bone21/build M=/home/ubuntu/bb/exploringBB/chp06/GPIO/tests/hello-linux-module modules
Makefile:4: recipe for target ‘all’ failed
I checked that inside ls -l /lib/modules/ there is 4.1.22-bone21 folder is present which is symbolically linked with the build pointing to /path_to_kernel_sources_on_pc_WHERE_I_BUILT_MY_KERNEL
Is this some error I did while building the image for BBB.How can I compile my kernel module?
Thanks and Rgds,
Rp
Hi Raul Piper,
You should probably not worry about the /lib/modules/4.1.22-bone21/ files.
But there might be a problem in your Makefile. You should try adding ‘all’ and ‘clean’ as PHONY targets in your makefile.
You can see this Makefile for reference : https://github.com/ZeekHuge/BeagleScope/blob/port_to_4.4.12-ti-r31%2B/examples/kernel_examples/n-blinky/module/Makefile
Good Luck
No It did not work.I just replaced the name of my module in your
example Makefile .Did you follow any pre-steps before this?
Rp
