Building the Poky Sato Image for Beagleboard
I have followed this wiki to build the "Poky Sato Image" with bitbake:
http://elinux.org/BeagleBoard/Poky
So i enter "bitbake omap-image-sato"
And i get the following error:
http://pastebin.com/m46f99ca1
Can someone help me?
Regards
Michael
Hello!
Interesting excerpt from pastebin is:
ERROR: certificate common name `www.omapzoom.org' doesn't match
requested host name `gforge.ti.com'.
To connect to gforge.ti.com insecurely, use `--no-check-certificate'.
Unable to establish SSL connection.
I have the same problem, something seems to be wrong with that
webserver's reorg, its redirections, and the SSL certificate. Try the
following:
$ cd $POKY/sources/
$ wget --no-check-certificate
https://gforge.ti.com/gf/download/frsrelease/170/1399/tiopenmax-0.3.5.tar.gz
$ md5sum tiopenmax-0.3.5.tar.gz > tiopenmax-0.3.5.tar.gz.md5
Then `bitbake -c rebuild tiopenmax`.
I'll see if something can be done with that certificate.
Greetings!
Daniel Díaz
yosoy@danieldiaz.org
Thanks for the reply.
It worked with tiopenmax.
Now i try the whole sato image.
Let see...
Regards
Michael
Now i have another error.
It could not fetch libgoo?!
See for yourself:
http://pastebin.com/m401d3999
Regards
Michael
Hello!
See for yourself:
The error is buried somewhere in the log:
Initialized empty Git repository in
/home/michi/beagleboard/poky/poky/sources/git/github.com.mrchapp.libgoo.git/.git/
/home/michi/beagleboard/poky/poky/build/tmp/staging/i686-linux/usr/bin/git-clone:
line 59: curl: command not found
Looks like your system doesn't have curl. Install it and git should be
able to git-clone. Try `bitbake -c rebuild libgoo`.
Greetings!
Daniel Díaz
