Button press interrupt confused?
(I am using Robert Nelsons kernel, updated and built yesterday.
I did not touch any GPIO etc settings.)
this morning I noticed something curious regarding the interrupts of
my beaglebone/LCD7 cape:
After a fresh reboot I did
    cat /proc/interrupts
and get (beside other things) this
    208: 0 GPIO left
    209: 0 GPIO right
    211: 0 GPIO up
    272: 0 GPIO down
    275: 0 GPIO enter
. Now I press each buttons (left/right/up/down/enter) of the LCD7 cape once.
Another
now gives me:
    208: 0 GPIO left
    209: 2 GPIO right
    211: 2 GPIO up
    272: 0 GPIO down
    275: 2 GPIO enter
Q: Why is the right/up/enter button counted twice and there is
no count for the left/down button?
Thank you very much for any help!
Best regards,
mcc
I’m having a problem with both the LCD3 and LCD4. Pressing the buttons seems to often cause an overwhelming auto-repeat sequence. At first I thought it was lack of debouncing, but my /proc/interrupts look reasonable: https://gist.github.com/pdp7/5670685 I’ve tried two BBB A5a with the May-20 image.
For the buttons that do work for you, do they work “normally” or do you see an erratic auto-repeat like effect, too?
Drew
Had similar problem on a custom 3730 board , turned out to be a pix mux issue, some pull up down uboot changes and Xorg had to be started with a -r arg
mmc,
iirc the gpio button driver generates an interrupt on the down press and another on the up release… so you should get two per button sequence.
the left/down buttons have pinmux issues that are being checked now… should have an update soon…
Dave
