C++ Compilation using Angstrom Tool chain Linker Errors
Hi all
I downloaded the angstrom tool chain from the angstrom web site.
I used the tool chain to compile to C project.
When i tried to Compiling a C++ project I get the following Linker
Errors.
Error: L6218E: Undefined symbol __aeabi_vec_new_nocookie.
Error: L6218E: Undefined symbol __aeabi_vec_ctor_nocookie_nodtor .
Error: L6218E: Undefined symbol __aeabi_vec_delete .
Error: L6218E: Undefined symbol __aeabi_vec_new_cookie.
Is it missing some shared object ?
Kindly help
Sundar
You didn't provide a command line so it is hard to know.
Make sure you link using g++ (not gcc) which will add libstdc++ and
any other bits required.
Basically i am using RVCT to compile for cortex A8. RVCT requires a
GNU tool chain for compiling for ARM Linux ( for the libraries and
headers ) . Hence used the ready made Angstrom tool chain from
http://www.angstrom-distribution.org/toolchains/
I downloaded the following tool chain
angstrom-2010.4-test-20100422-i686-linux-armv7a-linux-gnueabi-
toolchain-qte-4.6.2.tar.bz2
I configured RVCT to use Angstrom tool chain libraries and headers
I googled the error and found out that those symbols are defined in
libsupc++.so
could not locate the shared object in the tool chain
My command line goes like this.
armcc --cpu=Cortex-A8 --cpp --arm_linux_paths --
arm_linux_config_file=/opt/config/angstrom_c++.xml
where the xml file defines the headers and the libraries to be used.
any ideas?
Sundar
